gregkern
#1 Posted : 14 years ago
gregkern
The freezer is woking fine just the frig is not getting cold. I have control box apart and have tested thermostat with ohm meter on Rx1 setting I am getting a reading of.9. What might be suggestions of why frig is not getting cold?
#2 Posted : 14 years ago
Does the fan inside the freezer work?
Did you clean the condenser coils?
Does the fan next to the compressor work?
Remove the rear panel inside the freezer and check how the evaporator coils are covered with snow.
gregkern
#3 Posted : 14 years ago
gregkern
1) yes
2) where are condensor coils
3) yes
4) evaporator coils are covered in frost
#4 Posted : 14 years ago
The condenser coils are showed as #730 on the diagram.
How much frost is on the coils?
gregkern
#5 Posted : 14 years ago
gregkern
Coils have been cleaned and the Evaporator coils are completely covered and thick with ice. I unplugged last night to defrost.
gregkern
#6 Posted : 14 years ago
gregkern
Coils completely coverded with ice. unpluggged and let defrost.
#7 Posted : 14 years ago
It might be a problem with the defrost system. If it will reappear, let us know.
gregkern
#8 Posted : 14 years ago
gregkern
Starting to frost over and drug only at 45 degrees and freezer cold.
#9 Posted : 14 years ago
Give it 24 hours since you plugged it back. All panels must be in place.
greg a (Refrigerator & Freezer Repair)
by greg allen 12 years ago
greg (Dryer Repair)
by gsydor 13 years ago
Greg z (Washer Repair)
by Greg Z 13 years ago
Gregory Houraney (Refrigerator & Freezer Repair)
by carrieg 13 years ago
greg (Refrigerator & Freezer Repair)
by gazar 18 years ago
