gregkern
#1 Posted : Monday, April 25, 2011 10:23:48 AM(UTC)
gregkern
The freezer is woking fine just the frig is not getting cold. I have control box apart and have tested thermostat with ohm meter on Rx1 setting I am getting a reading of.9. What might be suggestions of why frig is not getting cold?
#2 Posted : Monday, April 25, 2011 12:26:39 PM(UTC)
Does the fan inside the freezer work?
Did you clean the condenser coils?
Does the fan next to the compressor work?
Remove the rear panel inside the freezer and check how the evaporator coils are covered with snow.
gregkern
#3 Posted : Monday, April 25, 2011 5:05:35 PM(UTC)
gregkern
1) yes
2) where are condensor coils
3) yes
4) evaporator coils are covered in frost
#4 Posted : Tuesday, April 26, 2011 12:13:28 AM(UTC)
The condenser coils are showed as #730 on the diagram.
How much frost is on the coils?
gregkern
#5 Posted : Tuesday, April 26, 2011 3:51:07 AM(UTC)
gregkern
Coils have been cleaned and the Evaporator coils are completely covered and thick with ice. I unplugged last night to defrost.
gregkern
#6 Posted : Tuesday, April 26, 2011 12:01:59 PM(UTC)
gregkern
Coils completely coverded with ice. unpluggged and let defrost.
#7 Posted : Tuesday, April 26, 2011 12:48:30 PM(UTC)
It might be a problem with the defrost system. If it will reappear, let us know.
gregkern
#8 Posted : Tuesday, April 26, 2011 1:50:38 PM(UTC)
gregkern
Starting to frost over and drug only at 45 degrees and freezer cold.
#9 Posted : Tuesday, April 26, 2011 2:04:05 PM(UTC)
Give it 24 hours since you plugged it back. All panels must be in place.
greg a (Refrigerator & Freezer Repair)
by greg allen 4/15/2013 8:47:02 AM(UTC)
greg (Dryer Repair)
by gsydor 2/9/2012 12:50:07 PM(UTC)
Greg z (Washer Repair)
by Greg Z 1/27/2012 5:22:22 PM(UTC)
Gregory Houraney (Refrigerator & Freezer Repair)
by carrieg 1/17/2012 10:59:25 AM(UTC)
greg (Refrigerator & Freezer Repair)
by gazar 9/26/2007 9:36:59 PM(UTC)
