Forum Rank:: Member
:) no power to ice maker on need instructions on how to test
Forum Rank:: Member
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Groups: APP Team
Hi. You need to check first the thermal fuse in the icemaker's harness (black wire possibly). If it's open most likely you should replace the icemaker, because it's overheats. Part number: AP4427021
Forum Rank:: Member
:) I need to know if the door switch is the only other part to test that supply power to the ice maker the icemaker and wire harnise are good .
Groups: APP Team
If the freezer light is OK, then the switch is the only part between the control board and isemaker fuse.
simon.
Forum Rank:: Member
:) if the freezer door switch is ok where is the control board and is there a test for it.
Groups: APP Team
Hi. Did you check the switch? Does the freezer light works? Your control board is inside the control panel in the refrigerator Part number: AP5657149
Simon.
Forum Rank:: Member
water silinoid only has 14.2 volts the freezer light works silinod oms start at 200 and go down to 194 is that nomal
Groups: APP Team
Hi.
Have you checked the door switch as I instructed you? Why are you checking water solenoid if the problem is - no voltage to the icemaker?
Simon.
Forum Rank:: Member
I have power to the ice maker the switch is good I do not have power to the water silinoid
