2 Pages12>
greg allen
#1 Posted : Monday, April 15, 2013 8:47:02 AM(UTC)
greg allen
:) no power to ice maker on need instructions on how to test
greg allen
#2 Posted : Monday, April 15, 2013 8:50:29 AM(UTC)
greg allen
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Simon / APP Team
#3 Posted : Monday, April 15, 2013 11:34:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check first the thermal fuse in the icemaker's harness (black wire possibly).
If it's open most likely you should replace the icemaker, because it's overheats.
Part number: AP4427021
Part number: AP4135008
Next check the door switch.
With the switch closed there should be continuity between C (RD) and NO (V/WH).
Part number: AP4008827
Here are the breakdown diagrams and Freezer Liner parts for Whirlpool GX5SHDXTQ00 - AppliancePartsPros.com
Post the results.
Simon.
greg allen
#4 Posted : Monday, April 15, 2013 1:02:00 PM(UTC)
greg allen
:) I need to know if the door switch is the only other part to test that supply power to the ice maker the icemaker and wire harnise are good .
Simon / APP Team
#5 Posted : Monday, April 15, 2013 1:12:09 PM(UTC)
Simon / APP Team
Groups: APP Team
If the freezer light is OK, then the switch is the only part between the control board and isemaker fuse.
simon.
greg allen
#6 Posted : Tuesday, April 16, 2013 1:50:20 AM(UTC)
greg allen
:) if the freezer door switch is ok where is the control board and is there a test for it.
Simon / APP Team
#7 Posted : Tuesday, April 16, 2013 9:31:48 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did you check the switch?
Does the freezer light works?
Your control board is inside the control panel in the refrigerator
Part number: AP5657149
Simon.
greg allen
#8 Posted : Thursday, April 18, 2013 6:28:40 AM(UTC)
greg allen
water silinoid only has 14.2 volts the freezer light works silinod oms start at 200 and go down to 194 is that nomal
Simon / APP Team
#9 Posted : Thursday, April 18, 2013 8:52:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Have you checked the door switch as I instructed you?
Why are you checking water solenoid if the problem is - no voltage to the icemaker?
Simon.
greg allen
#10 Posted : Saturday, April 20, 2013 2:17:13 AM(UTC)
greg allen
I have power to the ice maker the switch is good I do not have power to the water silinoid
2 Pages12>
