oven not heating on bake or broil
Originally Posted by: carey0413  oven not heating on bake or broil broiler wont come on nor the bake
Originally Posted by: carey0413  broiler wont come on nor the bake oven will not get hot
Originally Posted by: carey0413  oven not heating on bake or broil Carey, Your range is a "gas" unit and has a spark ignition system. Do the top burners spark and ignite ? Can you see or hear the bake and broil burners clicking when you turn the oven ON ? There are a couple of possibilities based on your post, beside checking fo loose connections and broken wires, A bad DSI spark module, Part number: AP3672576
Model # MGR5775QDS Oven Element does not get hot
Originally Posted by: James M SR  Model # MGR5775QDS Oven Element does not get hot James, That model number has a "glow bar" ignition sydtem, it's a bit different than the previous model, You need to remove the oven bottom panel, and program the bake cycle and observe the glow bar, it should start to glow in a few seconds, if it doesn't glow you need to check the black carborundum area to see if it's cracked or broken. if you have a multi meter you need to check the wires for 120 VAC from the control to the igniter. If it does glow but never achieves a "white" hot appearance, the glow bar is weak and cannot trigger the valve switch to open and release gas, you can verify that procedure with a multi meter as well , there should be 3.2 to 3.6 VAC across the 2 wires on the bake burner valve. Part number: AP4096758
Hi, our oven has also been identified as having a malfunctioning gas valve. Do you have a schematic of where this part is located in the oven? I have reviewed the schematics on your website for this oven but cannot find this particular part.
Thanks in advance, JRV
Originally Posted by: JRV  Hi, our oven has also been identified as having a malfunctioning gas valve. Do you have a schematic of where this part is located in the oven? I have reviewed the schematics on your website for this oven but cannot find this particular part.
Thanks in advance, JRV JRV, There are three different ranges discussed in the post. Could you get us a model number so we can assist you more effectively. In most cases you can remove the oven racks, and oven bottom panel, to access the igniter and valve to test or observe the ignition process. :) :) :)
Thanks for the quick response. The oven is a MAYTAG MGR5775QDS RANGE- S/C F/S GAS.
Thanks, JRV
Originally Posted by: JRV  Thanks for the quick response. The oven is a MAYTAG MGR5775QDS RANGE- S/C F/S GAS.
Thanks, JRV JRV, Thanks for the update. The procedure to access the bake burner igniter is the same as the previous post: Open or remove the oven door and racks. carefully remove the oven bottom panel, remove the flame spreader from the burner tube. Program a bake cycle and temperature and observe the igniter for a glow and gas ignition. As noted in the previous post, you can usue a meter to check the voltage on the wires at the safety valve, or observe the igniter, it should have a "white hot" glow/color to it in 60 seconds or less, if it's working proper. :) :) :)
