54troy2448
#1 Posted : Tuesday, October 28, 2008 5:19:21 PM(UTC)
54troy2448
I had the heating unit replaced less than a year ago and it has stopped heating again. I pulled the heating element and none of the coils seam to be fine, there not burnt thru or anything. Is there something else that could prevent it from heating up. Thank You
SublimeMasterJW
#2 Posted : Tuesday, October 28, 2008 7:15:00 PM(UTC)
SublimeMasterJW
The number one problema will be the high limit mounted on the TOP of the heating element' housing. UserPostedImage
It comes with both the bottom limit and the top one for a reason. The fat one is set for 250°F and the top one(smaller of the 2) is a 300°F limit. Replace them both. Make sure you do not have a blocked outside vent. That is what causes the failure. Restricted air flow causes the limit to open because the control thermostat does not get satisfied before the limit dies from rapid heat buildup in the heater element's housing and that is mostly due to a blocked vent. It would not hurt to give the inside of the dryer a once over with a good shop vac.
Troy2448
#3 Posted : Wednesday, October 29, 2008 8:29:13 AM(UTC)
Troy2448
I will give this a try. Thank you so much.
Troy
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
