garycart
#1 Posted : Monday, April 4, 2011 4:57:29 PM(UTC)
garycart
I installed a whirlpool duet on a ground fault plug and an electronic water shut off valve. It trips the ground fault and faults out the water valve. Is this a common problem? It runs fine on a regular plug and not run at all with the electronic water valve. The ground fault is required by code for this install.
sidfink43
#2 Posted : Wednesday, April 6, 2011 4:44:35 PM(UTC)
sidfink43
These auto shut off valves are a world of trouble. I am assuming what is happening is that the machine is drawing too much power to try to get water through the shut off valves.
You can try different shut off valves, but if you cannot get one set to work then you have a choice of taking them off permanently, or taking them off to use the machine.
I understand you want to protect against a flood. Metal hoses are not perfect, but they give you a lot of protection against a hose rupture.
garycart
#3 Posted : Wednesday, April 6, 2011 4:59:23 PM(UTC)
garycart
have you ever had a problem with them running on a ground fault plug
sidfink43
#4 Posted : Wednesday, April 6, 2011 5:21:42 PM(UTC)
sidfink43
Yes, they are also a problem. I am not aware of code provisions that require a GFI, particularly if the washer is on a separate circuit.
Guest (4)
Possible dryer electrical problem (Dryer Repair)
by Dmillbhawk 8/1/2013 10:43:43 AM(UTC)
Do I have electrical problem? Soap dispenser? (Dishwasher Repair)
by roger20 3/13/2012 3:42:47 PM(UTC)
electrical problem (Oven Repair (including Ranges and Cooktops))
by robertwgeorge 2/9/2012 6:44:19 PM(UTC)
Electrical problem (Dishwasher Repair)
by capndavid2001 8/31/2010 6:08:08 AM(UTC)
Maytag Dryer - first noise, now also electrical problem (Dryer Repair)
by RobBroekhuis 11/7/2009 2:23:58 PM(UTC)
Electrical problem (Washer Repair)
by hb6306 9/10/2009 12:55:10 PM(UTC)
Icemaker front panel electrical problem (Refrigerator & Freezer Repair)
by ttvor 6/20/2009 2:10:55 PM(UTC)
Electrical Problem (Garbage Disposer Repair)
by Debra Carlin 11/15/2008 6:04:36 PM(UTC)
Electrical problem (Refrigerator & Freezer Repair)
by mcbdallas 2/19/2008 11:27:42 AM(UTC)
