Sgate
#1 Posted : Friday, October 24, 2008 5:08:33 AM(UTC)
Sgate
I have a Whirlpool dishwasher that stays in the wash cycle and will not advance. It eventually needs to be shut off/cancelled. I was told a possible bad thermostat. If so can someone help locate and how to test/replace this part(s)? Thank you!
v2k04
#2 Posted : Friday, October 24, 2008 6:20:22 AM(UTC)
v2k04
You should probably start by putting the machine in a service mode.remove the lower kickplate and behind that will be instructions on how to do it. see if it passes the test you can put an amp probe on the orange wire coming off thermastat thats wired in series with the heater if it draws amperage then the heater and stats are ok on that would only leave the board thats bad
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Dishwasher is stuck in wash cycle (Dishwasher Repair)
by cskoyen 2/5/2012 1:36:36 PM(UTC)
Washer Stuck in Wash Cycle (Washer Repair)
by misti5768 9/28/2011 12:09:54 PM(UTC)
Dishwasher stuck in wash cycle (Dishwasher Repair)
by JD Childs 7/3/2011 7:13:29 PM(UTC)
Roper stuck in wash cycle (Washer Repair)
by LiThiuME3 8/8/2010 2:32:54 PM(UTC)
Whirlpool Washer Stuck in Wash Cycle (Washer Repair)
by dansmith60 10/24/2009 8:18:59 AM(UTC)
Stuck in Wash Cycle (Dishwasher Repair)
by bill_s 7/22/2009 5:40:49 PM(UTC)
Bosch DW stuck in wash cycle? (Dishwasher Repair)
by greway 4/13/2009 8:07:55 AM(UTC)
