I need to replace the lid switch on my series 90 washer. The consol has two screws in the front (at an angle). I had removed these but still cannot figure out how to get the consol off and get the top of the machine off to access the switch.
There should be 2 clips, one on each side about 2 inches from the corners. You can use a putty knife to release these and raise the lid. Nat
Remove the screws, pull console foward 1/2" and rotate over backwards, remove the 3 wire connector to the lid switch, remove the 2 GOLD colored clips, Tilt cabinet foward and slide off the washer.:)
thanks for the information
There does not appear to be any clips there. As I look at it there are plastic somethings at each corner.
Hi Glen, These clips are #6 on the break down diagram. Insert a flat screwdriver into the front edge of the clip and pry back. - The part number for the lid switch is AP3094500 Gene.
Thanks for the great information. I am now in the final stages of putting the machine back together. I really appreciate all of the great info all of you have given me...
