I have a problem with my washer machine, it does agitate and drain the water, but does not spin. I checked the belt and is good.When the machine hit the spin cycle you can hear the water pump and the motor working even though that motor shaft is no moving at all, but does not spin. After about 5 minutes of listening to the soun(motor, water pump)the motor start getting blazing hot.Please guys i need your help!
Originally Posted by: memin  I have a problem with my washer machine, it does agitate and drain the water, but does not spin. I checked the belt and is good.When the machine hit the spin cycle you can hear the water pump and the motor working even though that motor shaft is no moving at all, but does not spin. After about 5 minutes of listening to the soun(motor, water pump)the motor start getting blazing hot.Please guys i need your help! oh by the way the model is WCSR4170DAWW, thanks
Originally Posted by: memin  I have a problem with my washer machine, it does agitate and drain the water, but does not spin. I checked the belt and is good.When the machine hit the spin cycle you can hear the water pump and the motor working even though that motor shaft is no moving at all, but does not spin. After about 5 minutes of listening to the soun(motor, water pump)the motor start getting blazing hot.Please guys i need your help! anybody?this forumSUCKSSSSSSSSSSS
Originally Posted by: memin  oh by the way the model is WCSR4170DAWW, thanks this forum is the best you must learn how to use it. If your not up to diagnosing and repairing your stuff. Actuall hands on. Its not for you. By the wayIm in the same GE boat as you so good luck to both of us!:)
Originally Posted by: johny2thumbs  this forum is the best you must learn how to use it. If your not up to diagnosing and repairing your stuff. Actuall hands on. Its not for you. By the wayIm in the same GE boat as you so good luck to both of us!:) Beliveme my friend if i could do that ,i wont be here asking for help. What about the forums are for members who have the same problems to help each others.That is exactly what is not happening in this forumyaking a good look to all the differents old post where people ask for help and they got a reply months later GOOD HELP. bye
