On this GE SxS, the water dispenser does not dispense any water,
I have checked the Water Solenoid - OK. I am guessing there is a restriction in the water line somewhere between the Solenoid and Dispenser Head. I am suspecting a frozen water line behind the Freezer Door Liner.
Is there anything I should check BEFORE I go to the time and expense of tearing into the door liner...??
Are there any known issues on this GE model with regards to this problem..??
Any and all information would be apprecicated.
:confused:
When was the last time you changed your filter? If the filter hasn't been changed is a while try that before tearing into your door. Nat
YUP....Brand new filter....no difference.
