frankhd52
#1 Posted : Friday, March 18, 2011 11:37:50 AM(UTC)
frankhd52
Question by Frank
My refrigerator a GE Model GSS201EPDWW is not freezing or cooling. I replaced the mother board with no avail. PLEASE any sugestions before I junk it for a new one. Thank You, Frank
Read more: Part Details - GE Main control board assembly, part number: AP4436216
Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
#2 Posted : Saturday, March 19, 2011 2:05:42 AM(UTC)
Replacement parts for General Electric GSS20IEPDWW Refrigerator | AppliancePartsPros.com
FYI: It is a 20i not a 201
Here is a manual. It is the best I can do as GE likes to keep everything a secret so tech info is scarce.
31-9072 Arctica Profile GE Side-by-Side Refrigerator Service Manual - ApplianceDigest.com
You will have to join the site but it is free and this is a good site for appliance DIYer's.
First you have to determine if the compressor is running. You can usually hear it also you should be able to feel it vibrating and it should be warm.
If it is not running then you may have a control problem (no voltage to the compressor). This may be the control board but also could be bad thermistors etc. If it is getting voltage then it could be a bad compressor or start device.
If it is running then remove the evaporator cover inside the freezer so you can see the coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or frost only in one area, you have a sealed system problem. This would be an expensive repair as you need a pro and there is no guarantee of a long term fix. Usually it makes more sense to put the dollars into a new unit.
Here are a couple good links on basic fridge repair and troubleshooting.
http://www.applianceaid.com/frig.html
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
You will probably need a muti-meter
Frigidaire not freezing or cooling (Refrigerator & Freezer Repair)
by Vhaskell 1/15/2017 12:16:48 PM(UTC)
by Darmour88 12/27/2015 10:51:49 PM(UTC)
GE Refridgerator is not freezing or cooling. (Refrigerator & Freezer Repair)
by ChestyPuller 8/16/2015 10:20:43 AM(UTC)
by raylhouse 6/23/2015 7:17:01 PM(UTC)
Whirlpool refrigerator not freezing or cooling (Refrigerator & Freezer Repair)
by Sandp516ggg 4/26/2014 7:35:36 PM(UTC)
Not freezing or cooling (Refrigerator & Freezer Repair)
by Shaybyrdo 12/30/2013 10:46:27 AM(UTC)
refrigerator is running but not freezing or cooling (Refrigerator & Freezer Repair)
by bbrothers726 5/13/2013 4:44:49 PM(UTC)
GE fridge not freezing or cooling (Refrigerator & Freezer Repair)
by Teresa111 6/26/2012 7:43:49 AM(UTC)
kenmore side by side fridge/freezer not freezing or cooling (Refrigerator & Freezer Repair)
by tspires 10/23/2010 10:03:05 AM(UTC)
by dghby 5/7/2009 5:21:10 AM(UTC)
crosley shelvador fridge not freezing or cooling hear clicking noise (Refrigerator & Freezer Repair)
by noddef2000 8/18/2007 4:04:15 AM(UTC)
