Vhaskell
#1 Posted : Sunday, January 15, 2017 12:16:48 PM(UTC)
Vhaskell
After renters left and electricity was turned off. We have come up to work on the home several times and it ran fine. Mine you we turned off all electricity everytime we left. The freezer started making a loud squealing noise off and on and eventually it stopped freezing but the fridge worked. Now neither work.
Can someone tell me if it is lost cause or is there something I can do?
Dean Haustead
#2 Posted : Monday, January 23, 2017 9:07:04 PM(UTC)
Dean Haustead
I faced the same problem last year, for it at first you may check the presence of voltage, if there is no problem you should check the compressor and fan, if there is no problem you should contact with freezer company. They will make a perfect solution to you.
Frigidaire not freezing or cooling (Refrigerator & Freezer Repair)
by Darmour88 12/27/2015 10:51:49 PM(UTC)
by raylhouse 6/23/2015 7:17:01 PM(UTC)
