zehner001
#1 Posted : Wednesday, March 16, 2011 7:24:53 AM(UTC)
zehner001
the heated dry cycle does not shut off. anytime the door is closed the element heats up. A friend told me it may be the thermostat needs replaced but I want to know if that is correct.
#2 Posted : Wednesday, March 16, 2011 4:43:28 PM(UTC)
Most likely the problem is a bad control board.
- The control board Part number: AP4390034
Heat element won't shut off (Dryer Repair)
by BigEd313 5/21/2016 11:39:33 AM(UTC)
Heat element won't shut off when door open (Dryer Repair)
by Jack B 7/30/2015 7:46:02 AM(UTC)
Heat element on and off (Dryer Repair)
by Butcheeyboy 2/26/2015 7:12:29 AM(UTC)
electric heat element glowing with dyer off and door open (Dryer Repair)
by albertb 11/18/2014 5:53:06 PM(UTC)
Heat element bad? (Dryer Repair)
by pendley 7/26/2014 5:23:47 PM(UTC)
the lower heat element in oven doesnt heat (Oven Repair (including Ranges and Cooktops))
by lickenem 4/21/2014 7:53:43 PM(UTC)
How do I access the heat element & thremal fuses? (Dryer Repair)
by RJess 11/11/2013 5:32:33 PM(UTC)
Dryer not heating enough after replacing heat element (Dryer Repair)
by lfshadow 8/12/2013 6:33:40 PM(UTC)
Lower heat element will not turn off (Oven Repair (including Ranges and Cooktops))
by NicholasHubbard 2/24/2013 6:33:38 PM(UTC)
GE glass top oven popped after replacing heat element (Oven Repair (including Ranges and Cooktops))
by eksta 12/20/2012 4:56:27 PM(UTC)
Electric not geting to heat element (Oven Repair (including Ranges and Cooktops))
by scotchdrnkr 7/16/2012 5:45:29 AM(UTC)
No heat and leads to oven heat element only showing 110volts (Oven Repair (including Ranges and Cooktops))
by nobull1466 4/18/2012 7:32:12 AM(UTC)
by m3kpierce 1/27/2011 9:07:16 AM(UTC)
replacing heat element (Dishwasher Repair)
by notsohandy 10/19/2010 8:16:41 AM(UTC)
Heat element not shutting off (Dryer Repair)
by racefann3 10/2/2010 9:37:01 AM(UTC)
