m3kpierce
#1 Posted : Thursday, January 27, 2011 9:07:16 AM(UTC)
m3kpierce
I replaced heat element and cutoff-tml. the heat element turns on and off during a cycle. is this normal
magician59
#2 Posted : Thursday, January 27, 2011 9:24:02 AM(UTC)
magician59
Yes. This is normal. That's what you hear as the cycle continues. The thermostats are turning the element off and on to regulate the temperature.
Heat element won't shut off (Dryer Repair)
by BigEd313 5/21/2016 11:39:33 AM(UTC)
Heat element won't shut off when door open (Dryer Repair)
by Jack B 7/30/2015 7:46:02 AM(UTC)
Heat element on and off (Dryer Repair)
by Butcheeyboy 2/26/2015 7:12:29 AM(UTC)
electric heat element glowing with dyer off and door open (Dryer Repair)
by albertb 11/18/2014 5:53:06 PM(UTC)
Heat element bad? (Dryer Repair)
by pendley 7/26/2014 5:23:47 PM(UTC)
the lower heat element in oven doesnt heat (Oven Repair (including Ranges and Cooktops))
by lickenem 4/21/2014 7:53:43 PM(UTC)
How do I access the heat element & thremal fuses? (Dryer Repair)
by RJess 11/11/2013 5:32:33 PM(UTC)
Dryer not heating enough after replacing heat element (Dryer Repair)
by lfshadow 8/12/2013 6:33:40 PM(UTC)
Lower heat element will not turn off (Oven Repair (including Ranges and Cooktops))
by NicholasHubbard 2/24/2013 6:33:38 PM(UTC)
GE glass top oven popped after replacing heat element (Oven Repair (including Ranges and Cooktops))
by eksta 12/20/2012 4:56:27 PM(UTC)
Electric not geting to heat element (Oven Repair (including Ranges and Cooktops))
by scotchdrnkr 7/16/2012 5:45:29 AM(UTC)
No heat and leads to oven heat element only showing 110volts (Oven Repair (including Ranges and Cooktops))
by nobull1466 4/18/2012 7:32:12 AM(UTC)
heat element (Dishwasher Repair)
by zehner001 3/16/2011 7:24:53 AM(UTC)
replacing heat element (Dishwasher Repair)
by notsohandy 10/19/2010 8:16:41 AM(UTC)
Heat element not shutting off (Dryer Repair)
by racefann3 10/2/2010 9:37:01 AM(UTC)
