Gboyz
#1 Posted : Wednesday, October 10, 2007 12:26:01 AM(UTC)
Gboyz
Dryer runs but no heat generated, Changed heating element, still no change.
Appreciate any help.
#2 Posted : Wednesday, October 10, 2007 2:51:45 AM(UTC)
Common failure items, thermal fuse, circuit breaker, burnt wire. Should have a meter to check things.
Gboyz
#3 Posted : Wednesday, October 10, 2007 6:48:08 AM(UTC)
Gboyz
No burnt wires, did test power source to element and no power read.
Pegi
#4 Posted : Wednesday, October 10, 2007 1:20:19 PM(UTC)
Pegi
Check the cut-off fuse on the side of the heating element canister, the one above the safety thermostat....this is assuming you have 240 volts going to the dryer???
Gboyz
#5 Posted : Wednesday, October 10, 2007 6:38:05 PM(UTC)
Gboyz
Yes, 240v is read. Is there a way to test the cut off fuse. I tested accross the fuse on the resistance scale and did not get a reading (open).
#6 Posted : Thursday, October 11, 2007 12:56:14 AM(UTC)
That is your problem.These come as a kit with a safety thermostat. Thermostat is self-resettable and saves the fuse from blowing P # 279973
Check your dryer venting and remove clogs all the way to outside, they sell a 4 inch brush for this.
Appliance parts pros should have the kit, just call.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
