nspitz
#1 Posted : Wednesday, October 8, 2008 7:21:48 AM(UTC)
nspitz
Went to start dryer, Set timer, then went to hit start button. No clicking noise like usual. Lately I needed to hold the start button for a brief time to start the dryer. The door switch seems to be functioning. Any suggestions? Thanks
nspitz
#2 Posted : Wednesday, October 8, 2008 7:24:51 AM(UTC)
nspitz
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Wednesday, October 8, 2008 9:06:58 PM(UTC)
Originally Posted by: nspitz Go to Quoted Post
...Lately I needed to hold the start button for a brief time to start the dryer...
Did it make a humming noise at that time?
nspitz
#4 Posted : Thursday, October 9, 2008 6:14:23 AM(UTC)
nspitz
No humming noise. I have replaced the starter switch and thermal fuse. Now the starter switch makes a click sound when I press it in, but still nothing. I don't know how old this dryer is and I have already spend $45 on parts. I don't want to dump money into a this dryer if it is a loosing battle. Thanks
Nancy
#5 Posted : Thursday, October 9, 2008 3:23:22 PM(UTC)
Hi Nancy,
Most likely the problem is a bad motor. You have to remove the bottom panel and the idler pulley. Turn the motor pulley to see how free it's rotating. Then you have to check the motor windings for continuity according to the wiring diagram. Post the results.
Here are the break down diagrams for the Whirlpool dryer Model LGR7646DQ0
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
