207 Pages«<113114115116117>»
#1141 Posted : Wednesday, March 2, 2011 6:19:27 PM(UTC)
Brian,
You can find the instructions on the third page in this thread in the reply addressed to bohemian.
Brian R
#1142 Posted : Wednesday, March 2, 2011 6:47:50 PM(UTC)
Brian R
Brian,
Do I check with fridge on or off. MY BAD, I just reread page #3 - and it reads "UNPLUG FRIDGE".
As far as the parts that you suggest to also replace if mother board is bad, are they easy to replace?
Were talking a novice here.
Brian
#1143 Posted : Thursday, March 3, 2011 12:17:52 PM(UTC)
Brian,
Lets do one thing at a time. So do the troubleshooting first. Good luck.
Brian R
#1144 Posted : Thursday, March 3, 2011 1:50:38 PM(UTC)
Brian R
Gene, The impedance between the orange pin at J7 and the Blue wire from J9 is 3.386 k ohms. What next? Thanks
#1145 Posted : Thursday, March 3, 2011 3:19:17 PM(UTC)
Brian,
Remove the rear panel in the freezer and check the defrost heater and thermostat for continuity. The defrost thermostat must be really cold at that time.
Brian R
#1146 Posted : Thursday, March 3, 2011 6:20:04 PM(UTC)
Brian R
Took apart defrost Heater and checked. The circuit is open. So I guess I need to order a new defrost heater.
#1147 Posted : Friday, March 4, 2011 1:18:02 PM(UTC)
Yes Brian. You are right.
- The defrost heater Part number: AP3183311
Brian R
#1148 Posted : Friday, March 4, 2011 6:07:46 PM(UTC)
Brian R
THANKS Gene,
Replaced the heater today. I will check in three days to see if frost builds up but I doubt it.
I did not install the mother board and I can not send it back either.
Ow well, I can keep it on hand just in case or try to sell and get some $$$$.
THANKS AGAIN Gene.
Your the best
Brian R
#1149 Posted: : Monday, March 7, 2011 5:33:15 PM(UTC)
You are welcome Brian. I'm hoping the new heater fixed the problem.
Why you can not return the mother board?
transplant99
#1150 Posted : Saturday, March 19, 2011 4:42:06 AM(UTC)
transplant99
Hi gene, first off an amazing amount of info on this subject and thanks for that.
I have a Magic Chef MN rc20ln-2a and have the frost build up on the back of the freezer. My problem is I cannot locate anything that looks like the defrost timer and am a bit stumped.
Any ideas?
I might add that there are two coils one on top of the other, starting at the bottom and going up. Right above these coils is a black round thing with two wires coming off it going to a board of some sort. Now I dont think that is the timer as i see no where that you could turn it with a screwdriver. Everything else is at the top behind the fan assembly.
I really am a bit mystified.
Edit 2! OK I did some looking around and the only component visible that I described above id a thermostat....so I am guess everything is behind the fan assembly at the top?
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
