12 Pages«<678910>»
TONY7666
#71 Posted : 14 years ago
TONY7666
My model number for my under cabinent installed microwave is MH1150XMQ-0 and it took about 15 minutes. My model is white. Open the door and remove 3 screws close to handle positions. With two butter knives slowly pry and carefully remove the black plastic on the door. It is pressed into place but be careful around the corners. As you get close to area near the handle ( where you removed the three screws) the door will separate . The outer door panel with the outer glass is fixed and hinged. The inner section with the screen glass is also hinged. Slightly move these sections apart to replace screw for the door handle on the outer section. I did not have to remove either the microwave or door. Hope this helps.
robinm
#72 Posted : 14 years ago
robinm
Hi all,
I've purchased the door handle replacement for my microwave from this site (model: GMH3204XVS, Whirlpool Gold) and was surprised that it didn't come with instructions ;). Has anyone worked on this model before? I think it is a Lowe's specific version of the 3205 model.
Thank you!
#73 Posted : 14 years ago
Originally Posted by: robinm Go to Quoted Post
Hi all,
Thank you!
I believe you can find some useful instructions as well as the video clip on one of the previous pages in this thread.
Here are the breakdown diagrams and Door parts replacement parts for WHIRLPOOL GMH3204XVS0 Microwave Oven/Hood 2.0 Cu. Ft. | AppliancePartsPros.com
robinm
#74 Posted : 14 years ago
robinm
Thanks, Gene and ApplianceHelper! I will give it a shot :) Much appreciated.
fxbruton
#75 Posted : 14 years ago
fxbruton
Once I got #2 off, I had to get the front panel off - The tabs are only on the top and bottom. Using a knife (dull - whatchout) I moved the plastic, lifting the tabs off the metal and put 2 playing cards between the two to keep tab from re-seating. Did this along top, and botton popped out - rest was "easy".
mingtelu
#76 Posted : 14 years ago
mingtelu
Originally Posted by: peters4n6 Go to Quoted Post
just bought the replacement handle for the GE Advantium SCA1001FSS.
After removing part# 1805 there is only access to the upper handle screw. The lower screw is behind a second inner panel. I removed the 6 screws from this inner panel, but I can't get it to budge. It seems like a lot of people don't have access to the 2nd(lower) screw. The advice I keep seeing is to look at the video (to remove the inner panel) which does not solve the problem. Any further input from the kind experts would be appreciated.
Got a replacement handle from you quickly. Now I have the exactly the same problem accessing the lower screw which is covered by another panel! Help!!
Admin / APP Team
#77 Posted : 14 years ago
Admin / APP Team
Rank: Administration
handyman49
#78 Posted : 14 years ago
handyman49
I have taken my door off before and it is very easy .Open door ,take screws out and remove black liner around inside window.
funkyvailchick
#79 Posted : 14 years ago
funkyvailchick
I was completely baffled as to how I was going to replace this handle until I watched your video. Thank you so much! :)
lanham8darby
#80 Posted : 14 years ago
lanham8darby
I
Originally Posted by: Admin / APP Team Go to Quoted Post
Mark,
I didn't mention any clips. What I was trying to say was #2, which is the inner frame, clips on to #4, inner door. Your model may have different components in it, but the door is the same. See diagram below:
UserPostedImage
I had also same problem. But it get solved soon by your given solution. Thanks for sharing. Keep updating.
GE Profile #PVM917DFBB microwave handle removal (Microwave Repair)
by trifive 5 years ago
microwave handle repair (Microwave Repair)
by rthill01 12 years ago
Replacing microwave handle (Microwave Repair)
by gregx5 14 years ago
Microwave handle (Microwave Repair)
by mrorvis 14 years ago
Microwave handle repair (Microwave Repair)
by rburton61 14 years ago
microwave handle broke off (Microwave Repair)
by bigbro 15 years ago
Installing Microwave handle (Microwave Repair)
by Buckey1 16 years ago
by gdevas 16 years ago
Microwave Handle (Microwave Repair)
by tyohe@yoheconsulting.com 16 years ago
Kenmore microwave handle repair (Microwave Repair)
by ginasal 16 years ago
Broken off GE Microwave Handle pn #AP3187809 (Microwave Repair)
by mrbotto 16 years ago
Microwave Handle replacement (Microwave Repair)
by Yusuf 16 years ago
Install GE Microwave handle (Microwave Repair)
by icandoitmyself454 16 years ago
How to install new microwave handle (Microwave Repair)
by Chalcook 16 years ago
GE Microwave Handle Replacement (Microwave Repair)
by Graham Brown 16 years ago
12 Pages«<678910>»
