Dishwasher does not fill when Hi-Temp setting is on. When Hi-Temp set to off dishwasher fills and runs properly.
Try this test and we'll see what we can figure out for you. With no cycle selected and the dishwasher sitting idle, press and hold the Hi-temp and the Start pads simultaneously for one second. The dishwasher will start through the test cycle. Post what you find.
Nat
There is no start pad so I don't know how to do what you say.
The model posted shows a touch pad on the left side of the control panel. I'll double check. Nat
Sorry, there is a touch pad on the left. There is a dial on the right.
