GLENNA CAGLE
#1 Posted : Wednesday, October 1, 2008 7:32:41 AM(UTC)
GLENNA CAGLE
When I hit the control on my oven control panel to raise the temp it automatically just goes down in temp even if i hit it to go up in temp. 350 is as high as it goes . It cooks fine at that temp but is all it will do on bake. If I put the oven on broil the temp will go where it is suppose to. I was told I needed a new control board which is almost $500. Is this what you think the problem is with the oven. The oven is 9 years old. Thank you for responding soon.
libertyappl
#2 Posted : Wednesday, October 1, 2008 7:37:00 AM(UTC)
libertyappl
can you post your model numer. the number you have is a part number or something. you can find the model number on the frame of the unit after opening the drawer on the bottom.
Nat
GLENNA CAGLE
#3 Posted : Wednesday, October 1, 2008 7:45:51 AM(UTC)
GLENNA CAGLE
Nat
I HAVE MODEL #886380SP086 ( MAYBE THE FIVE I GAVE YOU WAS ACTUALLY A S. THE O COULD POSSIBLY BE ZERO OR VICE VERSA/ THE SERIAL NUMBER IS x30401075.
I WILL HAVE TO CHECK AT LUNCH IF THIS MODEL # STILL DOES NOT WORK FOR YOU.
libertyappl
#4 Posted : Wednesday, October 1, 2008 7:51:02 AM(UTC)
libertyappl
It should look something like this.... RF386PXEQ
GLENNA CAGLE
#5 Posted : Wednesday, October 1, 2008 10:49:38 AM(UTC)
GLENNA CAGLE
Whirlpool Model # RBS305PD86. Believe this will be correct.
GLENNA CAGLE
#6 Posted : Wednesday, October 1, 2008 11:15:31 AM(UTC)
GLENNA CAGLE
model # is RBS305PD86
libertyappl
#7 Posted : Wednesday, October 1, 2008 11:55:02 AM(UTC)
libertyappl
Glenna,
The control board for your oven is only about $275 if you order it from this site. The part # is AP3009794. And you Could put it in yourself and save lots of $$ which is a lot cheaper than a new one!!
Nat
GLENNA CAGLE
#8 Posted : Wednesday, October 1, 2008 12:08:58 PM(UTC)
GLENNA CAGLE
Do You Think That That Is What The Problem Is With The Oven And I Have Been Told The Right Thing?
libertyappl
#9 Posted : Wednesday, October 1, 2008 1:50:48 PM(UTC)
libertyappl
Glenna
that is definately what it sounds like!
Nat
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
GE Electric double oven control panel part number (Oven Repair (including Ranges and Cooktops))
by Steveg297 6/20/2020 6:48:16 AM(UTC)
How to remove Superba Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by gofastr 4/5/2018 7:20:54 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 8:04:15 PM(UTC)
Jenn Air Stove/Convection/Oven Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by moboney 12/26/2015 7:37:27 AM(UTC)
New Frigidaire oven Control Panel/Board - wiring help (Oven Repair (including Ranges and Cooktops))
by IGoofed 11/16/2015 8:06:12 PM(UTC)
How to remove ribbon on oven control panel (Oven Repair (including Ranges and Cooktops))
by Fulvous3 11/18/2014 3:22:19 PM(UTC)
PLES389ECE Oven control panel not working (Oven Repair (including Ranges and Cooktops))
by tfmc369 10/26/2014 8:34:27 AM(UTC)
maytag oven control panel wiring (Oven Repair (including Ranges and Cooktops))
by cmkowals 12/12/2013 1:19:45 PM(UTC)
Help finding an apparently obsolete Kitchenaid oven control panel (Oven Repair (including Ranges and Cooktops))
by jmasgat 10/15/2013 11:32:31 AM(UTC)
Jennair oven control panel partial function failure (Oven Repair (including Ranges and Cooktops))
by Jcowin 5/20/2013 8:09:17 AM(UTC)
Oven control panel losses power intermittently (Oven Repair (including Ranges and Cooktops))
by tommyboy84 4/9/2013 12:28:17 PM(UTC)
New oven control panel not working (Oven Repair (including Ranges and Cooktops))
by MarshalW 2/13/2013 9:05:14 AM(UTC)
Thermador double oven control panel (Oven Repair (including Ranges and Cooktops))
by Malcolm Phillips 1/7/2013 4:40:27 PM(UTC)
