Fulvous3
#1 Posted : 10 years ago
Fulvous3
I am trying to replace the control panel on my jenn-air oven. Does anyone know how you remove the old ribbon from the circuit board? It is attached to the board via a black "clip." I found that the clip pops backwards to release the two small holes on the ribbon, but I am unsure if you are supposed to simply pull the ribbon free (feels very tight when I try and I am scared of ripping the ribbon) or if the entire black clip mechanism pulls out of the circuit board.
Thanks for your help!
#2 Posted : 10 years ago
Parts for Jenn-Air JES9800AAW Range - AppliancePartsPros.com
If you click on the description or picture of the control [panel (item 1 in section 03) a new page will open with more views of the panel.
It shows that the ribbon cable does not have a connector at the control board end.
