2 Pages12>
maxepr1
#1 Posted : Saturday, February 26, 2011 8:34:28 AM(UTC)
maxepr1
I have a Kennmore (1069730580) refrigerator that the freezer is not freezing the food anymore. There is no frost/ice buildup in the freezer and I have already cleaned the coils to no avail. It appears that the fan is running but it doesn't feel like blowing that hard? The refrigerator seems to be working fine?
#2 Posted : Sunday, February 27, 2011 1:30:20 AM(UTC)
If you have any cooling and the compressor is running, you have a bad refrigerant leak, or a bad compressor. Check the compressor, it should be warm and vibrating. Also verify the condensing fan is running.
maxepr1
#3 Posted : Sunday, February 27, 2011 2:58:07 AM(UTC)
maxepr1
Thanks Rich, I was looking a little more at it today and the compressor was running but there is no airflow in either the frig or freezer. So I would guess that the Evap. fan is not working? Were is it located under the unit or inside the frig?
#4 Posted : Sunday, February 27, 2011 5:12:04 AM(UTC)
Remove the freezer back panel and check the evaporator fan motor. If no meter, you can pull it and stick 115 volts to it to see if it will run.
maxepr1
#5 Posted : Sunday, February 27, 2011 5:40:37 AM(UTC)
maxepr1
Thanks again Rich, which back panel? On the outside of the frig. or inside the frig? Can't find any IPC's for this model? I have the wiring diagram. I have a meter but before I take the unit outside and tear it down, which I might not need to do I figure I would ask. Plan on doing this hopefully tomorrow.
maxepr1
#6 Posted : Sunday, February 27, 2011 6:23:02 AM(UTC)
maxepr1
Rich, I think I answered my own question. The fan is benind the back panel of the freezer, right?
#7 Posted : Sunday, February 27, 2011 2:37:31 PM(UTC)
Right, just remove the food and panel, motor should have windings and 115 volts printed on it.
maxepr1
#8 Posted : Tuesday, March 1, 2011 2:30:51 PM(UTC)
maxepr1
Rich, 115 going to Evap. fan, bearings bad fan just humming. Spinning it jumps started it but it moans and sputters. Took it out and lubed it up temp. fix. Part on order should get me through till it gets here! Thanks Rich!
#9 Posted : Wednesday, March 2, 2011 12:18:29 AM(UTC)
Good job, normally very little oil is needed in these as they come already lubricated with special non-detergent, light oil.
maxepr1
#10 Posted : Wednesday, March 2, 2011 5:50:09 AM(UTC)
maxepr1
Normally, but when the bearings blown out it take allot of grease!
Guest (4)
Freezer Problems (Refrigerator & Freezer Repair)
by CJPolinsky 12/6/2016 4:09:14 PM(UTC)
GE fridge freezer problems (Refrigerator & Freezer Repair)
by robinleigh 2/16/2016 5:33:39 PM(UTC)
GE Bottom freezer problems after main board swap (Refrigerator & Freezer Repair)
by Busy 9/25/2015 9:05:47 AM(UTC)
25326442100 Kenmore Freezer Problems (Refrigerator & Freezer Repair)
by cover 5/21/2015 6:47:34 PM(UTC)
by Bill120 9/2/2014 12:41:21 PM(UTC)
Freezer problems (Refrigerator & Freezer Repair)
by GaryPil 4/21/2014 9:31:00 AM(UTC)
Whirpool Freezer Problems (Refrigerator & Freezer Repair)
by Eds 3rd 9/3/2013 7:34:01 AM(UTC)
by jclisk 9/6/2012 7:44:55 PM(UTC)
by dymetz62 5/19/2012 4:48:18 PM(UTC)
by Pop 12/1/2011 2:05:32 PM(UTC)
Chest Freezer Problems (Refrigerator & Freezer Repair)
by rhondap 7/12/2011 1:07:11 PM(UTC)
Frigidaire Freezer problems (Refrigerator & Freezer Repair)
by trountre 6/28/2011 7:50:02 AM(UTC)
by danno621 7/13/2010 3:08:48 PM(UTC)
whirlpool freezer problems (Refrigerator & Freezer Repair)
by wally28 4/8/2010 5:17:19 PM(UTC)
Icemaker/freezer problems (Refrigerator & Freezer Repair)
by bofusmosby 11/29/2009 5:20:13 PM(UTC)
2 Pages12>
