9 Pages«<45678>»
#51 Posted : Monday, February 14, 2011 6:03:57 PM(UTC)
I would do one thing at a time. The vent has to be done first.
oasis
#52 Posted : Tuesday, February 15, 2011 9:16:41 AM(UTC)
oasis
Thank you for the info!
trmart
#53 Posted : Tuesday, February 15, 2011 9:27:46 AM(UTC)
trmart
You are welcome. Hopefully the problem is solved.
I suspect these are my problems as well. I have removed them, but how do I test them?
TRMART
#54 Posted : Tuesday, February 15, 2011 12:22:47 PM(UTC)
TRMART
Can you be more specific on the problem please?
The complete model number of the dryer would not hurt too.
trmart
#55 Posted : Tuesday, February 15, 2011 12:45:02 PM(UTC)
trmart
Whirlpool Estate Model # TGDX640PQ0
Based on my novice troubleshooting, I suspect the problem is my gas coils. I have removed them, but don't know how to test them to see if they are functioning properly. Recommendations?
#56 Posted : Tuesday, February 15, 2011 1:17:52 PM(UTC)
What exactly is wrong with the dryer?
mqcheng64
#57 Posted : Tuesday, February 15, 2011 1:31:30 PM(UTC)
mqcheng64
Hi Gene,
It works like brand new. The problem start out with the bad ignitor and replaced with a brand new defective one. Thanks
#58 Posted : Tuesday, February 15, 2011 2:55:29 PM(UTC)
You are welcome. I'm glad you were able to find it.
Just wanted to say thank you for sharing your diagnosis and repair with us. It's not often we see an intermittent problem caused by a faulty igniter.
trmart
#59 Posted : Wednesday, February 16, 2011 4:30:55 AM(UTC)
trmart
My problem is that the tumbler works but doesn't heat. Here is what I have diagnosed so far...
- Gas is on
- Breakers are set
- Fuse on back of dryer work
- Ignitor box glows red for 10-15 seconds then stops
I have removed the gas valve coils, as they may be a likely suspect, but I don't know how to test them to determine if they are the problem. Ideally, I would prefer not to get the replacement coils, install them, then determine that they weren't the problem.
#60 Posted : Wednesday, February 16, 2011 11:56:41 AM(UTC)
You can find the instructions on how to check the coils in one of our previous threads: http://forum.appliancepartspros...er-runs-but-no-heat.html
Check them and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TGDX640PQ0 29`` GAS DRYER | AppliancePartsPros.com
Gas Dryer running but no heat (Dryer Repair)
by cpenn42 8/26/2011 4:50:25 PM(UTC)
9 Pages«<45678>»
