Originally Posted by: Gene  Looks like the sequence switch gone bad. - The part number for the sequence switch is AP2039701 Gene. replaced the switch its still doing the same thing is there any thing else to check, like the wire housing could those be dirty or bad.
Mak,
It looks mysterious. We've tried everything and I do not know what else to check. Probably you have to call a certified tech to check the dishwasher.
