2 Pages12>
mak
#1 Posted : Monday, September 8, 2008 8:21:43 AM(UTC)
mak
my dishwasher fills up runs then drains. it fills up again runs then drains. on the last fill up it runs but does not drain. I replaced the valve body gasket because the flapper was worn out. I'm also replacing the pump impeller because it was leaking. what else do i need to check.
#2 Posted : Monday, September 8, 2008 1:32:56 PM(UTC)
I would also check the piston & nut assembly (#564 on the break down diagram).
- The part number for the piston & nut assembly is AP2617344
Here are the break down diagrams for the GE dishwasher Model GSD5130D00WW
mak
#3 Posted : Tuesday, September 9, 2008 12:32:22 AM(UTC)
mak
I already pulled the piston and nut assembly out and cleaned it up, it was frozen in the up position it seems to working now. While i was researching this problem i read something about a timer, i have a friend that can test it for me, but i can't find it on any of the diagrams. I need to know where it is and if this could be part of the problem:)
#4 Posted : Tuesday, September 9, 2008 10:39:34 AM(UTC)
There is no regular timer in your dishwasher. All cycles operated by the control board (#905 on the break down diagram) and the sequence switch (#904 on the break down diagram).
When I recommended to check the piston & nut, I meant to check the cone part of it. When it is in the upper position the hole must be completely closed.
Check if any of the status lights on the left side of the control panel are blinking at the end of the cycle.
Post the results.
mak
#5 Posted : Friday, September 12, 2008 1:07:18 AM(UTC)
mak
Post the results.
I replaced the piston and nut and the pump seal and impeller and its doing the same thing it drains at the beginning of the wash but not at the end the motor is running, you can hear the impeller spinning. there's like a click then it sounds like something else kicks on then it drains except at the end. there are no blinking lights at the end of the cycle. could my pump be going bad or is it something else
#6 Posted : Friday, September 12, 2008 1:24:52 PM(UTC)
Remove the bottom panel and check if the drain solenoid (on the left side of the main pump) engaged properly at the last drain.
mak
#7 Posted : Friday, September 12, 2008 2:15:31 PM(UTC)
mak
solenoid is working plunger goes down every time
#8 Posted : Friday, September 12, 2008 2:45:45 PM(UTC)
It is very possible there is a foreign object inside the drain hose which is floating back and forth. Disconnect the drain hose from the air gap (if there is any) or from the garbage disposer, put this end of the hose in a bucket and run the drain cycle.
Also make sure the drain hose is not kinked and/or twisted.
mak
#9 Posted : Saturday, September 13, 2008 12:42:52 PM(UTC)
mak
i disconnected the hose and drained it into a bucket. it drained all but the last cycle. the solenoid went down the motor was running. but i never heard the pump kick on, like the other 4 times.
#10 Posted : Saturday, September 13, 2008 2:45:39 PM(UTC)
Looks like the sequence switch gone bad.
- The part number for the sequence switch is AP2039701
Dishwasher wont drain - had new motor (Dishwasher Repair)
by brady5885 10/31/2015 9:51:05 AM(UTC)
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
by doanhtran@gmail.com 7/9/2012 7:50:20 PM(UTC)
by virg912 6/24/2012 6:55:23 AM(UTC)
by calla929 6/19/2012 4:28:22 PM(UTC)
Dishwasher wont drain (Dishwasher Repair)
by Randy Moore 5/13/2012 7:30:46 AM(UTC)
dishwasher wont drain even though solenoid engages (Dishwasher Repair)
by rafjr94 1/8/2012 2:47:20 PM(UTC)
Dishwasher Wont Drain. (Washer Repair)
by darfug 1/3/2012 2:06:41 PM(UTC)
Bosch Dishwasher wont drain after wash (Dishwasher Repair)
by ddzc 7/20/2011 1:56:49 PM(UTC)
Bosch dishwasher wont drain (Dishwasher Repair)
by dishwasherDave 10/7/2010 12:57:28 PM(UTC)
by torque_dwf 9/4/2010 4:29:20 AM(UTC)
ge profile triton dishwasher wont drain (Dishwasher Repair)
by tstevens77 7/1/2010 11:49:22 AM(UTC)
Whirlpool Dishwasher wont drain water (Dishwasher Repair)
by shirump 5/30/2010 8:38:25 AM(UTC)
frigidaire dishwasher wont drain (Dishwasher Repair)
by imorrill2003 2/24/2010 12:46:19 PM(UTC)
by kmt12708 2/1/2010 7:13:22 AM(UTC)
2 Pages12>
