LSchm
#1 Posted : 17 years ago
LSchm
This is a stand alone four burner range with oven. Recently the left two burners fail to light but can be light with a match. The right two burners light on demand.
When any of the burner controls are set to the light position, I hear and see the spark of the igniter on the right two burners but do not see the spark on the left two burners. I have cleaned the metal surfaces around the igniters on all burners but this did not appear to help.
Here are my questions:
1.) It would appear that the burner control switches are OK since I get spark activity from all four burner controls. How can I determine if the problem is in the Igniter Wiring Harness (dwg #3, Item #8) or in the Igniter Module (dwg#3, Item #8)?
2.) How do I gain access to the Igniter Module or Wiring Harness? From the rear of the unit or where?
Thank you,
LSchm
#2 Posted : 17 years ago
Most likely the problem is a bad igniter module.
According to the break down diagram it should be on the back of the unit, under the rear cover.
- The part number for the igniter module is AP2126193
Here are the break down diagrams for the Frigidaire range Model FGF374CCSG
jood
#3 Posted : 16 years ago
jood
i have a tappan model TGF336aue. gas range with elec. ignitors. the stove-top ignitors do not work any more. they do not click or spark like they used to. any thoughts?
#4 Posted : 16 years ago
Jood,
Most likely the problem is a bad spark (aka ignition) module.
- The part number for the spark module is AP2126193
jood
#5 Posted : 16 years ago
jood
Thank you Gene. Would this module be located behind the cover at the top of the unit or behind the larger [lower] cover of the unit
#6 Posted : 16 years ago
It could be under the top panel or behind the rear cover.
jood
#7 Posted : 16 years ago
jood
do you have any diagrams for this model tappan TGF336AUE
jood
#8 Posted : 16 years ago
jood
gene, how do i know if our problem is the "top burner ignition switch"- part # PS437415 as opposed to the part you noted
#9 Posted : 16 years ago
If no one igniter works then it has nothing to do with ignition switches.
P.S.By the way, I did not see any opposed replies and the part# PS437415 does not look as a valid Frigidaire part number.
