This is a stand alone four burner range with oven. Recently the left two burners fail to light but can be light with a match. The right two burners light on demand.
When any of the burner controls are set to the light position, I hear and see the spark of the igniter on the right two burners but do not see the spark on the left two burners. I have cleaned the metal surfaces around the igniters on all burners but this did not appear to help.
Here are my questions:
1.) It would appear that the burner control switches are OK since I get spark activity from all four burner controls. How can I determine if the problem is in the Igniter Wiring Harness (dwg #3, Item #8) or in the Igniter Module (dwg#3, Item #8)?
2.) How do I gain access to the Igniter Module or Wiring Harness? From the rear of the unit or where?
Thank you,
LSchm
Most likely the problem is a bad igniter module. According to the break down diagram it should be on the back of the unit, under the rear cover. - The part number for the igniter module is AP2126193 Here are the break down diagrams for the Frigidaire range Model FGF374CCSGGene.
i have a tappan model TGF336aue. gas range with elec. ignitors. the stove-top ignitors do not work any more. they do not click or spark like they used to. any thoughts?
Jood, Most likely the problem is a bad spark (aka ignition) module. - The part number for the spark module is AP2126193 Gene.
Thank you Gene. Would this module be located behind the cover at the top of the unit or behind the larger [lower] cover of the unit
It could be under the top panel or behind the rear cover.
do you have any diagrams for this model tappan TGF336AUE
gene, how do i know if our problem is the "top burner ignition switch"- part # PS437415 as opposed to the part you noted
If no one igniter works then it has nothing to do with ignition switches.
Gene. P.S.By the way, I did not see any opposed replies and the part# PS437415 does not look as a valid Frigidaire part number.
