donkris67
#1 Posted : Friday, February 4, 2011 9:15:29 AM(UTC)
donkris67
The dryer will start and run until it gets to the cool down cycle it then shuts off and will come back on for at least 1 hour what can be the problem cause when it running it works great.
#2 Posted : Saturday, February 5, 2011 12:03:07 AM(UTC)
Replacement parts for WHIRLPOOL LER5848EQ2 | AppliancePartsPros.com
Are you sure that it always stops when it hits cool down or do you just think it stops then?
If it always stops at the same place on the timer then it would point toward a timer problem.
If you set the timer to the start position, will it start up?
Have you tried different cycle types and heat settings?
For instance air only to see if anything changes.
The reason I ask is that your shut down symptoms sound like the motor is overheating and tripping it's internal thermal protect. You then have to wait for the motor to cool down and the thermal protect to reset before the unit will restart.
Try turning the drum, in the correct direction, it should turn fairly easily. You may want to try this on a couple other units to get a feel for it. You are trying to see if the drum is too hard to turn and is putting too much load on the motor.
Check that the seals in the unit close to the motor/blower are OK and they are not allowing hot air to blow onto the motor.
donkris67
#3 Posted : Saturday, February 5, 2011 11:12:32 AM(UTC)
donkris67
Thank you for the advice I will try these things I appreaciate all the suggestions I can get .
donkris67
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
