sean.ky
#1 Posted : Wednesday, October 3, 2007 10:52:18 AM(UTC)
sean.ky
My wife and I purchased a new Whirlpool (MSD 2651 HEW) side by side refrigerator 2 years ago from Home Depot.
I started making a loud busing noise (about every 10 minutes) and food in the freezer was thawing.
I called Home Depot and Whirlpool and the both told me it was out of warranty, so I called an appliance repairman. By the time he showed up the noise stopped and the freezer started freezing again. He checked the compressor current draw and said it was good. so he cleaned the condenser coils (on the bottom of the unit) as best he could. It worked great for about a week. Now the same problem is occurring again.
If I unplug the unit and allow it to sit for about 20 to 30 minutes and plug back in, the noise is gone and the freezer works fine.
#2 Posted : Thursday, October 4, 2007 1:50:53 AM(UTC)
You probably have a hard starting compressor,or maybe a outlet voltage problem. Check your wall socket voltage while compressor is trying to start, if well below 115 volts, you have a socket problem.
If ok, click on your model # above and order the compressor start relay.Make sure you get the original factory part.Do NOT use a hard start 3n1 unit.
If this fails to fix the problem, you have a bad compressor.
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 3/15/2024 12:21:35 PM(UTC)
Frigidaire FGHS2655PF5A Gallery side by side (Refrigerator & Freezer Repair)
by Rube 2/27/2024 7:56:33 PM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Whirlpool Side by Side Gold Series - circa 2010 (Refrigerator & Freezer Repair)
by ForumUser1 12/18/2023 8:29:01 AM(UTC)
whirlpool side by side freezing up periodically (Refrigerator & Freezer Repair)
by Guest 11/2/2023 6:19:56 AM(UTC)
GE Adora Side by Side Freezer won't get below 20 degrees (Refrigerator & Freezer Repair)
by Guest 10/16/2023 7:24:15 AM(UTC)
Whirlpool Side By Side Ice Maker Power Failure (Refrigerator & Freezer Repair)
by Bollweevil 9/29/2023 6:11:03 PM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
