5 Pages<12345>
WAG2170
#21 Posted : 16 years ago
WAG2170
Please help, have the same problam, what repair did you do? wag2170@oponline.net thantks in advance
WAG2170
#22 Posted : 16 years ago
WAG2170
Hello Gene, what is Whirlpool talking about with Service Pointer k8178446 for a control panel reading PF. I am unable to use control panel seems locked up, only reading PF. clocks works fine. Whats next. What repaired AGRAYWALL problem..........HELP
#23 Posted : 16 years ago
What is the complete model number of the unit and the color of the control panel?
WAG2170
#24 Posted : 16 years ago
WAG2170
Hello Gene, here is the info you requested to help me. GW395LEPB00
WAG2170
#25 Posted : 16 years ago
WAG2170
Gene, forgot to tell you control panel is BLACK. By the way I have already replaced the circuit board. Still same problem PF
#26 Posted : 16 years ago
WAG2170,
If you can not set up the clock and/or eliminate "PF" after power was reset then, most likely, the problem is a bad membrane switch. I'm assuming when you said "I have already replaced the circuit board" you meant the clock.
- The part number for the membrane switch assembly is AP4263577
WAG2170
#27 Posted : 16 years ago
WAG2170
GENE, Thanks for your info. I failed to tell you that my Control Panel will not work at all. Lights up and clock works but unable to use any controls on Panel. I see that alot of people are haveing trouble with Whirlpool with this same problem, with panel reading PF, thanks in advance
johnmou
#28 Posted : 16 years ago
johnmou
Go ahead send e-mail to Whirlpool to complain the problem. As more complain to Whirlpool I hope they'll take some action, like "RE-CALL". see below for where to complain.
sample e-mail I send to -
Sent: 8/11/2008 12:23:45 AM
To: whirlpool_customerexperience@whirlpool.com
Subject: Whirlpool.com Email Us Form Submission
Here are more case has the same problem happen after one year warranty, But I
truely belive Whirlpool brand should last much longer, especialy at this higher
level product. see attached post from different web site.
http://forums.**********.com/range-repair/anyone-can-help-wit-my-oven-ctrl-panel-6570.html
http://forum.appliancepartspros...ot-work-2.html#post29679
#29 Posted : 16 years ago
WAG2170,
Looks like the problem is a bad membrane switch which comes as a part of a new, redesigned control panel.
I do not think Whirlpool will take it as a recall because this problem did not cause any danger to the consumers. Consumers could try to file a group lawsuit which is very hard and takes a very long time.
- The part number for the control assembly (included the membrane switch) is AP4263577
johnmou
#30 Posted : 16 years ago
johnmou
Hi Gene,
can you recommand any one serve San Gabriel city? would you give me a call 626.807.6115? please.
5 Pages<12345>
