Originally Posted by: Gene  Very likely you fixed the defrost problem by re-soldering that joint.
Both the evaporator and the condenser fans should run as long as the compressor is running.
Gene. Thanks for the reply, Gene. The refrigerator has been running almost 24 hours and there is no sign that the defroster has come on and the evap fan runs constantly. The water line is also frozen again. It's cold, but there is frost building on the evap. Any further suggestions? Thanks..
Normally the whole evaporator coils should be covered with thin frost. Does it look more than that?
Have you cleaned the condenser coils on the back of the refrigerator?
Originally Posted by: Gene  Normally the whole evaporator coils should be covered with thin frost. Does it look more than that?
Gene. The condenser coils were cleaned about two months ago. Toward the bottom of the coils, the frost was much thicker. What would cause the through-the-door water line to freeze?
Originally Posted by: jmann1  ...Toward the bottom of the coils, the frost was much thicker... Put the freezer rear panel back in place to make sure there is good air flow and let the fridge run for a few more days. Then remove the panel and inspect the evaporator coils. Quote:...What would cause the through-the-door water line to freeze?... You may want to check the heaters (#29 or #33 on the diagram). Gene.
Originally Posted by: Gene  Put the freezer rear panel back in place to make sure there is good air flow and let the fridge run for a few more days. Then remove the panel and inspect the evaporator coils. You may want to check the heaters (#29 or #33 on the diagram). Gene. Could a bad control board cause all of this? It seems oddly coincidental that all of these problems occured at the same time.
It's not enough time to say that the defrost problem was fixed or it's still exist. Give it a few more days.
Originally Posted by: Gene  It's not enough time to say that the defrost problem was fixed or it's still exist. Give it a few more days.
Gene. Will do. It's back together and running now. I'll update in a few days. Thanks..
Hope you got to the bottom of the problem, jmann. This forum is such a great resource full of helpful people.
Gene. Gene, I'm right back where I was before. The water line is frozen and the evap coils are a solid block of ice. So much so that the inside panel of the freezer is bulging inward. The refrigerator section is not cold either. Based on what was already replaced in previous posts, any recommendations? I'm getting ready to curb this thing and buy a new one.. Thanks..
Originally Posted by: MisterAppliance  Hope you got to the bottom of the problem, jmann. This forum is such a great resource full of helpful people. I agree. It's nice to know that there are people out there that take the time to help. I try to do the same when I can.
