207 Pages«<1213141516>»
Keith Leslie
#131 Posted : Monday, September 8, 2008 3:24:06 PM(UTC)
Keith Leslie
So, I went into the parts diagram and there is no defrost timer for my GE refrigerator. now what?
#132 Posted : Monday, September 8, 2008 3:29:20 PM(UTC)
Keith,
What is the complete model number of the refrigerator?
What is wrong?
Keith Leslie
#133 Posted : Tuesday, September 9, 2008 2:07:58 AM(UTC)
Keith Leslie
Gene,
GE model #GSS25UFMC-BB. The the refrigerator is too warm. There is no air coming thru the port window and some frost on the back of the freezer. The motor run continuously. I checked the parts diagram for a defrost timer and apparently it does not have one. Now what?
pz7rx8
#134 Posted : Tuesday, September 9, 2008 3:43:51 AM(UTC)
pz7rx8
I have a Maytag MSD2756GE with a similar problem. However, I have not noticed any frost build up of any kind. I normally keep the refrigerator temp control in the middle. I noticed the fridge getting warm and set the control all the way up. This seems to be working for now. I've checked for air flow and can feel cool air coming in at the top.
Joe
gnuage
#135 Posted : Tuesday, September 9, 2008 9:48:24 AM(UTC)
gnuage
Hi Gene,
My MayTag MSD2756DE refrigerator is getting warm, the freezer is working fine without any frost. I have visually inspect the evap fan behind the panel in the freezer, everything seems to be normal. No frost build up. All air vents are cleared as well. I have read your previous posting, look like it could be a bad damper control? If so what part do I need? Please advise.
Best Regards,
Frank
#136 Posted : Tuesday, September 9, 2008 10:51:00 AM(UTC)
Keith,
Looks like there is a problem with the defrost in your fridge. You can find the complete troubleshooting instructions in one of our previous posts: http://forum.appliancepartspros...igerator-too-warm-3.html
Here are the break down diagrams for the GE refrigerator Model GSS25UFMCBB
#137 Posted : Tuesday, September 9, 2008 10:56:34 AM(UTC)
Hi Joe,
Remove the rear cover in the freezer and check the evaporator coil. Normally it should be completely covered in light snow.
Remove the back cover and clean the condenser coil. Make sure the fan next to the compressor is running.
Post the results.
Here are the break down diagrams for the Maytag refrigerator Model MSD2756GEB
#138 Posted : Tuesday, September 9, 2008 11:02:03 AM(UTC)
Hi Frank,
What is the temperature in the freezer?
Did you feel cold air coming into the refrigerator?
Follow the instructions in the reply for Joe above. Post the results.
Here are the break down diagrams for the Maytag refrigerator Model MSD2756DEB
gnuage
#139 Posted : Tuesday, September 9, 2008 11:23:18 AM(UTC)
gnuage
Gene,
The freezer works just fine(I mean everything is well frozen). Behind the freezer back panel. I found evaporator coil is indeed covered with light snow like you described. Evaporator fan is spinning and blowing air. I can feel some air coming into the refrigerator from the top, not sure if the air flow is strong enough though. There is no frost build up in the freezer. Condenser coil is cleaned as well. I tried defrost it two days ago (thought the frost might have blocked the air flow), did not help.
Frank
gnuage
#140 Posted : Wednesday, September 10, 2008 7:15:17 PM(UTC)
gnuage
Gene,
The freezer is measured at 14 F while the refrigerator is at 48 F. I have done some search and suspect the damper door might not be wide open even
if I set it to 9.
Frank
Guest (16)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
