grumpa03
#1 Posted : Friday, January 14, 2011 3:03:17 PM(UTC)
grumpa03
dryer wont heat took front off held door button in an ran dryer did not see igniter glow what all should i check to resolve my problem
Joe / APP Team
#2 Posted : Friday, January 14, 2011 4:31:07 PM(UTC)
Joe / APP Team
Grumpa,
I presume, you have a multi meter and aren't shy around 120 VAC .
At the gas valve coils, disconnect the harnesses,
Start the dryer on a heat setting , in the harness check across the Black and Red wires, you should have 120 VAC, if you do, you need to check the igniter/glow bar and radiant sensor(black box on side of burner flue) for closed circuits.
If No 120 VAC you'll need to check all the thermostats, on the blower housing and burner flue, they should all be closed circuits at room temperature.
From there you would need to access the control board, and check the gas valve relay for 120 VAC out to the thermostats and gas valve.
If everything checks proper, you'd have to have a bad set of gas valve coils,
Part number: AP3094251
But I have the feeling, you may need the glow bar igniter,
Part number: AP3109449
Good Luck,
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
