2 Pages12>
Jennifer14
#1 Posted : Tuesday, January 11, 2011 10:51:25 AM(UTC)
Jennifer14
I just took my dryer out of storage, plugged it in, went to start it and it will not stay running. It ran fine before I put it in storage. I am not sure what part I need to order to get it working again. Please help!
#2 Posted : Wednesday, January 12, 2011 5:22:12 AM(UTC)
Replacement parts for General Electric DHDSR46EE1WW Electric dryer | AppliancePartsPros.com
Need a better description of exactly what is happening.
Jennifer14
#3 Posted : Wednesday, January 12, 2011 10:24:38 AM(UTC)
Jennifer14
I turned the start switch to the right and the dryer came on, but the second I let it go back to the left it turns off. So, the dryer will stay running as long as I'm holding the switch to the right.
#4 Posted : Thursday, January 13, 2011 12:31:21 AM(UTC)
On the motor there are two centrifugal switches, they are closed when the motor gets close to operating speed.
One of them connects in the heating coil, It ensures that the heating coil does not come on before there is air flow.
The other does 2 things.It disconnects the motor's start winding as leaving it energized would overheat the motor.
It also provides an alternate circuit path to keep the motor running when you release the start button. It is wired in parallel with the start switch.
This is probably your problem.
When you hold the start switch closed, do you get heat?
If not it could be that the centrifugal mechanism in the motor is broken or it may be so clogged with lint/dirt that it is not working.
If there is heat then you may have a bad connection to the switch or the switch is toast.
I cannot get wiring diagrams for GE units but the heater centrifugal switch is usually the one with the two red larger diameter wires going to it.
Jennifer14
#5 Posted : Thursday, January 13, 2011 7:19:50 AM(UTC)
Jennifer14
If I hold the start switch to the right it does stay running and there is heat. Once I let it go, it immediately turns off.
#6 Posted : Thursday, January 13, 2011 8:08:51 AM(UTC)
OK, that tells you that the centrifugal mechanism is working and closing the switches.
So either there is a bad connection somewhere or the other centrifugal switch for the motor is toast.
Jennifer14
#7 Posted : Thursday, January 13, 2011 8:12:56 AM(UTC)
Jennifer14
Someone told me that they think it is the motor itself and needs to be replaced. I don't know much about it, but I would think that it wouldn't run at all if it was the motor...right??? So, I will try to look up the switch and see about purchasing it. Would you be able to find the part number for me so I can order the correct one? Thank you so much for your help.
eepagazeepa
#8 Posted : Thursday, January 13, 2011 9:53:41 AM(UTC)
eepagazeepa
My dryer has been working beautifully until the end of an air cycle only (w/down pillows). Now the start button won't stay on. I don't seem to have heat either. It sounds like my problem might be the centrifugal mechanism and needs to be replaced. But, to see if it's clogged with lint (or feathers) will I see it, if I open the back? My dryer is not quite 5 yrs. old. Thank you!
#9 Posted : Thursday, January 13, 2011 11:56:28 AM(UTC)
Your friend is correct, the switches are not available as a separate item.
They are part of a motor assembly.
Part number: AP4295548
Click on the picture for more info.
Here is a good site with additional info on GE dryers.
http://www.applianceaid.com/ge-dryers.html
Jennifer14
#10 Posted : Thursday, January 13, 2011 12:40:11 PM(UTC)
Jennifer14
Thank you very much for your help.
Guest (7)
GE dryer will not stay running (Dryer Repair)
by aycarumba22 6/20/2017 5:34:31 PM(UTC)
Maytag dryer will not stay running unless you hold the start switch (Dryer Repair)
by J-Bird-Medic 8/28/2014 7:53:06 AM(UTC)
GE Dryer will not stay running when start button released (Dryer Repair)
by danielwik 7/26/2014 4:43:31 AM(UTC)
by duckb0y01 3/15/2014 10:11:53 AM(UTC)
dryer will not stay running, shuts off every 15 mins. (Dryer Repair)
by kamt2012 9/24/2013 9:11:13 AM(UTC)
Dryer will not stay running (Dryer Repair)
by upstatenyers 11/19/2012 9:50:08 AM(UTC)
by sticksofpraise 4/27/2011 6:34:11 PM(UTC)
electric dryer will not stay running (Dryer Repair)
by jerry aiello 10/16/2009 6:53:49 AM(UTC)
2 Pages12>
