moeenzo
#1 Posted : Wednesday, December 29, 2010 8:30:15 PM(UTC)
moeenzo
Hello,
Thanks a lot for your help on this
I have a Maytag elec. dryer model MED5740TQ. the timer will not advance in any cycle timed/auto dry.
I read that I need to change the time and some where else I read I need to change the control board.
Any help which one should I replace
Thanks so much.......that will make score a home run with the wife:)
ApplianceJunk
#2 Posted : Wednesday, December 29, 2010 9:03:21 PM(UTC)
ApplianceJunk
As a technician I would check to see if I have 120 volts to the timer motor with my volt meter. If I did (chances are that you do) then I would replace the timer.
If I did have voltage to the timer then I would trace it back to were I did have power to find the problem.
Chances are you will need to replace the timer.
moeenzo
#3 Posted : Saturday, January 1, 2011 8:00:54 AM(UTC)
moeenzo
Thanks a lot Appliance Junk for your reply
I checked and I see the timer's motor running and has sound when I put it on timmed drying.
Could it be the control board?!
Thakns a lot
Whirlpool Dryer - Timer Won't Advance in Auto (Dryer Repair)
by AMarkham40 12/10/2016 11:18:39 AM(UTC)
Is it safe to run dryer if timer won't advance? (Dryer Repair)
by Living 7/7/2015 7:22:15 PM(UTC)
GE Dryer Timer Won't Advance (Dryer Repair)
by tmhmah4 3/9/2015 5:09:49 PM(UTC)
roper dryer timer won't advance (Dryer Repair)
by jwb1977 7/10/2014 2:28:36 PM(UTC)
Maytag dryer timer won't advance during cycle (Dryer Repair)
by baseeight 1/24/2014 10:16:44 AM(UTC)
Kenmore - timer won't advance even with replacement (Dryer Repair)
by vickischow 8/6/2013 11:10:28 AM(UTC)
whirlpool dryer not heatting and timer won't advance (Dryer Repair)
by vero_09 11/8/2012 4:03:48 AM(UTC)
Series 80 Kenmore washer timer won't advance (Washer Repair)
by frugalastheyget 7/27/2012 11:27:28 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Timer won't advance in auto modes (Dryer Repair)
by sly1types 10/17/2011 2:29:33 PM(UTC)
Maytag dryer timer won't advance (Dryer Repair)
by Boolala 5/25/2011 8:09:41 AM(UTC)
Timer won't advance (Washer Repair)
by sheilakn 12/29/2010 2:44:35 PM(UTC)
Timer Won't Advance (Washer Repair)
by Scs8104 12/27/2010 8:25:46 AM(UTC)
Washer timer won't advance (Washer Repair)
by jbuckingham 9/20/2010 6:26:48 AM(UTC)
by tenacity1255 7/14/2010 11:06:00 AM(UTC)
