Scs8104
#1 Posted : Monday, December 27, 2010 8:25:46 AM(UTC)
Scs8104
My washing machine (Whirlpool LSR7233EQ0) will not automatically advance to the next cycle. I can manually advance the timer and the cycles work just fine. I am not sure if I need to replace the timer or if I need a new lid switch assembly with leads. Can you help? :confused:
magician59
#2 Posted : Monday, December 27, 2010 9:28:23 AM(UTC)
magician59
Is it the same in all the cycles? Does it stop in the same place every time?
Scs8104
#3 Posted : Monday, December 27, 2010 10:41:52 AM(UTC)
Scs8104
It is not the same in all cycles. The machine will start agitating after it fills to the correct water level but sometimes stops there. I have to manually adjust it to drain and then again to spin. However, sometimes it will automatically drain and go into the spin cycle. Other times, after filling a 2nd time (rinse cycle), the washer will stop and not automatically start agitating again.
magician59
#4 Posted : Monday, December 27, 2010 10:52:21 AM(UTC)
magician59
It sounds like you have a bad timer.
Whirlpool Dryer - Timer Won't Advance in Auto (Dryer Repair)
by AMarkham40 12/10/2016 11:18:39 AM(UTC)
Is it safe to run dryer if timer won't advance? (Dryer Repair)
by Living 7/7/2015 7:22:15 PM(UTC)
GE Dryer Timer Won't Advance (Dryer Repair)
by tmhmah4 3/9/2015 5:09:49 PM(UTC)
roper dryer timer won't advance (Dryer Repair)
by jwb1977 7/10/2014 2:28:36 PM(UTC)
Maytag dryer timer won't advance during cycle (Dryer Repair)
by baseeight 1/24/2014 10:16:44 AM(UTC)
Kenmore - timer won't advance even with replacement (Dryer Repair)
by vickischow 8/6/2013 11:10:28 AM(UTC)
whirlpool dryer not heatting and timer won't advance (Dryer Repair)
by vero_09 11/8/2012 4:03:48 AM(UTC)
Series 80 Kenmore washer timer won't advance (Washer Repair)
by frugalastheyget 7/27/2012 11:27:28 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Timer won't advance in auto modes (Dryer Repair)
by sly1types 10/17/2011 2:29:33 PM(UTC)
Maytag dryer timer won't advance (Dryer Repair)
by Boolala 5/25/2011 8:09:41 AM(UTC)
Timer won't advance (Dryer Repair)
by moeenzo 12/29/2010 8:30:15 PM(UTC)
Timer won't advance (Washer Repair)
by sheilakn 12/29/2010 2:44:35 PM(UTC)
Washer timer won't advance (Washer Repair)
by jbuckingham 9/20/2010 6:26:48 AM(UTC)
by tenacity1255 7/14/2010 11:06:00 AM(UTC)
