samspade
#1 Posted : Friday, December 31, 2010 12:14:51 PM(UTC)
samspade
Dryer turns on and off fine....at on position it turns just fine....no heat...any suggestions? Thanks in advance.....
#2 Posted : Saturday, January 1, 2011 3:58:41 AM(UTC)
Here is the parts breakdown.
Replacement parts for WHIRLPOOL LER5620KQ1 | AppliancePartsPros.com
First thing to check is power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next would be the heater itself. Should be around 10 to 12 ohms.
Next would be the thermal cut-off (Item 9 in Section 3).
If it is blown get back to us as there are other things you should check before replacing it.
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
