Gyro-Gearloose
#1 Posted : Monday, November 22, 2010 3:58:08 AM(UTC)
Gyro-Gearloose
I have a GE Profile French Door refridgerator, with the freezer on the bottom, and the icemaker inside the refridgerator in the upper left corner. Once the ice bucket is removed, you can press a tab and slide the icemaker unit front. However there is a cable attached to it that comes up the left side. I suspect there is a connector that has to be removed, but I can't see it. How do I remove the icemaker? It started acting up after we were away for 3 weeks during which the icemaker was turned off, as was the water. It makes ice normally and then stops for some reason. I've power cycled the refridgerator and sometimes that starts the icemaker working.
What's the trick to removing the ice maker?
brent pretzlaff
#2 Posted : Thursday, December 30, 2010 3:20:20 PM(UTC)
brent pretzlaff
after you remove the ice container there is a panel on bottom, left hand side with one screw towards the front. remove and slide forward, then
you can unplug the power cord and remove the ice maker.:)
Ice maker removal, side by side Whirlpool (Refrigerator & Freezer Repair)
by tizzmo 5/24/2021 12:58:40 PM(UTC)
Ice Maker Removal - LG freezer (Refrigerator & Freezer Repair)
by jameshere 3/22/2012 2:40:23 PM(UTC)
Ice maker removal (Refrigerator & Freezer Repair)
by Gail Marie 11/12/2011 8:50:19 AM(UTC)
ice maker removal (Refrigerator & Freezer Repair)
by oleblueyes 8/13/2011 5:05:33 AM(UTC)
Ice maker removal procedure (Refrigerator & Freezer Repair)
by fishnjim 6/6/2011 9:32:52 AM(UTC)
Maytag MFI2269VEM Ice Maker Removal (Refrigerator & Freezer Repair)
by Aquitard 11/10/2010 8:49:56 AM(UTC)
by cfuller201 6/11/2010 12:12:21 PM(UTC)
by delbertbstapp 1/31/2008 11:05:20 AM(UTC)
