heinzb
#1 Posted : Wednesday, December 29, 2010 4:13:17 PM(UTC)
heinzb
Water dispenser was drippimg. I ordered from you and replaced the intake valve unit. I was very carefull to cut the 1/4 and 5/16 tubing to make a square cut (old board was the screw in type) and not to pull on the tubing in order to connect it back up. The water dispensor worked fine. The next day as I checked it I found water all over the floor. In checking the source I found water coming drop after drop from the filter housing. I used a few choice words and disconnected the tubing and removed the filter housing.
I installed new tubing as I had the housing out in my hands to make sure
it was done correctly. I reinstalled the housing, lead the tubing to the rear, cut the tubes square again and reconnected them to the valve board.
I turned the water supply back on and it leaked. The words I used probably are brand new. NOW MY QUESTION IS BEFORE I GO TO BUY A NEW FRIG IS, (which I can not afford with social security) is there a chance that the filter housing connections are bad and or that whatever seals the new filter into place is bad. Of course if I was a plumber the repair bill at this time would exceed the cost of a new frig.
Your serious comments or suggestions would be much appreciated.
P.s. If I ordered a new filter housing, installed it and it would leak again
I probably would have an attack that I can not describe here.
Humor aside I would appreciate a quick response.
Thank you for your help
Heinz
Joe / APP Team
#2 Posted : Thursday, December 30, 2010 1:15:31 PM(UTC)
Joe / APP Team
Heinz
This is a duplicate of a previous thread and has been responded to
whirlpool frig. not working (Refrigerator & Freezer Repair)
by edward1946 11/20/2014 12:59:11 PM(UTC)
wHIRLPOOL FRIG LIGHT BLINKS (Refrigerator & Freezer Repair)
by WAGGY 10/5/2013 7:24:36 PM(UTC)
Side by side whirlpool frig ice/water dispenser, light not working (Refrigerator & Freezer Repair)
by LenZ 3/7/2013 5:16:57 AM(UTC)
Whirlpool Frig. touch pad malfunctions (Oven Repair (including Ranges and Cooktops))
by RandyMc 8/24/2012 8:47:48 AM(UTC)
by NDOGO 4/13/2012 12:47:00 PM(UTC)
Help With Whirlpool Frig-Freezer Fan Always On (Refrigerator & Freezer Repair)
by LashLaRue 2/8/2011 7:16:52 PM(UTC)
Whirlpool Frig (Refrigerator & Freezer Repair)
by heinzb 12/29/2010 4:09:22 PM(UTC)
Whirlpool Frig-Freezer good/Frig warm (Refrigerator & Freezer Repair)
by TD3 12/16/2010 10:47:32 PM(UTC)
whirlpool frig (Refrigerator & Freezer Repair)
by chipwing 8/17/2009 12:37:47 PM(UTC)
whirlpool frig (General Talk)
by Momsczam 11/28/2008 2:18:12 PM(UTC)
whirlpool frig compressor not running (Refrigerator & Freezer Repair)
by jim45 9/19/2008 5:49:54 PM(UTC)
Whirlpool Frig not working (Refrigerator & Freezer Repair)
by beanzy 6/17/2008 7:30:24 PM(UTC)
