Ok the one on the bottom looks like it goes to the empty prong, the clipped orange wire should be attached wityh the other wire on the thermal cutoff. If my memeory serves me!
Did you check, via continuity as to which or if both were actually not working?
well the one on the bottom does not go to the sensor because I tried it and it blew the circut. does it go the the empty prong on the heat element? I did try the continuity but I could be doing that wrong. The orange clipped one should go where?
the orange wire goes to the thermal cutoff's top prong? I dont understand why the directions show the prongs empty.
If I can get the piture to post I edited your pictures to show where to put the wires
See if you can understand my doodles. libertyappl attached the following image(s):
Sorry it took so long to get back with you. Thank you so much. I have time to work on it tomorrow. I will let you know how it goes. Katie
Thank you, Thank you, Thank you. I would have never been able to complete this without your help. I am so very grateful...:) I have completed my first do it your self appliance repair....yippy yippy yea!! Katie Hussett
