I would suggest getting an ohm meter, even a cheap digital one or calling a tech Nat
Hello, I have never been on one of these before. I cant afford a guy to come do this so I bought my parts, there here, I put them on less the wires reconnected. I dont want to short out parts, will there actually be wires that are not reconnected? I have two wires left and no where to put them? HELP:eek:
There should not be anywires left. post your model number please
which parts did you change out?
I changed the heating element, and thermal cut off ? when I installed those parts it had a note on the instructions that if there was a 3/16 terminal connected then I had to do some cutting and crimping on the jumper wire.. Thats where it got tricky for me:mad:
I could even take a picture, I just need to get this thing going again...ugggg
ok, and post the part number of the thermal cutoff. There are different ones
thermal cutoff kit 279816 here are a picture of new and the darker one with no wires is the older unit I took out :) katiehussett attached the following image(s):
I can tell you that the skinner orange one is not connected and it goes to where the timer control is. also there is a wire coming up from the bottom of the dryer (drum area) that is not connected anymore..
