kelly6825
#1 Posted : Tuesday, December 14, 2010 12:58:22 PM(UTC)
kelly6825
dryer would not start as if no power. checked plug and breaker at box and both okay. read on how to check switches and checked push start switch had ohms reading of 2. was going to check timer switch and did not know were to put tester leads. what should i check for next. had forum with magician59 with no results. kelly
magician59
#2 Posted : Tuesday, December 14, 2010 1:30:39 PM(UTC)
magician59
Are you saying you checked all the things I suggested and still get no power; or my suggestions didn't make any sense to you?
#3 Posted : Tuesday, December 14, 2010 1:37:47 PM(UTC)
Replacement parts for WHIRLPOOL LEQ8858JQ1 | AppliancePartsPros.com
Only way to ensure it has power is to use a meter
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Another high on the list item is the thermal fuse (Item 7 in Section 3.
Unplug the unit and the wire going to one side of the fuse.
Then measure the fuse with a meter, should be 0 ohms.
OR
Jiggery pokery method is:
Unplug the unit.
Short the two wires from the fuse together
Tape them so they cannot short to anything else.
Plug the unit in and give it a try.
If it is blown replace it ASAP as this is a critical safety device, burn your house down safety.
Also clean/check your vent system as this is the most common cause of this fuse blowing.
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
