2 Pages12>
ec2000
#1 Posted : Saturday, August 23, 2008 5:26:53 AM(UTC)
ec2000
sounds like its running, but no cooling at all, any common things
on this model ?
libertyappl
#2 Posted : Saturday, August 23, 2008 6:45:00 AM(UTC)
libertyappl
Views messages in topic : 3,097
Touch your compressor to see if it's warm or if you hear a clikcing noise near the compressor.
Nat
ec2000
#3 Posted : Saturday, August 23, 2008 12:57:18 PM(UTC)
ec2000
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
ec2000
#4 Posted : Saturday, August 23, 2008 1:00:34 PM(UTC)
ec2000
we unpluged it over nite now works,by doing that did we free up a relay
or a error in a chip allowing it to work again. watching it closely see if
happens again.
libertyappl
#5 Posted : Saturday, August 23, 2008 6:02:05 PM(UTC)
libertyappl
If it does that again repost with as much details as possible along with your complete model number
Nat
ec2000
#6 Posted : Sunday, August 24, 2008 4:25:31 AM(UTC)
ec2000
Thanks Nat
ec2000
#7 Posted : Monday, August 25, 2008 6:01:43 PM(UTC)
ec2000
model RM18F6WS Gibson small frezer bottom right side, ok once again not
cooling, i felt compresser its running very hot so i unpluged refrigerator
see if comes back on after cooling down
libertyappl
#8 Posted : Monday, August 25, 2008 6:08:30 PM(UTC)
libertyappl
Remove the back panel in the freezer and check for ice there, if you have ice look for the defrost thermostat and test whith an ohm meter for continuity, if none the replace that part. Thaw completely with hair dryer which will get you by until you can get a partin and you will have to defrost it anyway.
Nat
ec2000
#9 Posted : Tuesday, August 26, 2008 4:00:58 AM(UTC)
ec2000
thanks Nat, it came on again after being unpluged over nite ill try your
suggestion later today and let you know results Earl
ec2000
#10 Posted : Tuesday, August 26, 2008 3:50:09 PM(UTC)
ec2000
ok Nat, the refridgerator quit coolinga again this afternoon,opening the
frezer door you can see the coils are frosted over,i removed 1 screw that
cover the fan however i also removed 2 more that looks like plastic cover
in back should pull off however it wont come off, im thinking the thermostat most likely would be there. now i havent give it the big pull
trying not to break that cover. so still trying to get deeper into back of
freezer Earl
Guest (6)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
2 Pages12>
