2 Pages12>
ec2000
#1 Posted : 16 years ago
ec2000
sounds like its running, but no cooling at all, any common things
on this model ?
libertyappl
#2 Posted : 16 years ago
libertyappl
Touch your compressor to see if it's warm or if you hear a clikcing noise near the compressor.
Nat
ec2000
#3 Posted : 16 years ago
ec2000
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
ec2000
#4 Posted : 16 years ago
ec2000
we unpluged it over nite now works,by doing that did we free up a relay
or a error in a chip allowing it to work again. watching it closely see if
happens again.
libertyappl
#5 Posted : 16 years ago
libertyappl
If it does that again repost with as much details as possible along with your complete model number
Nat
ec2000
#6 Posted : 16 years ago
ec2000
Thanks Nat
ec2000
#7 Posted : 16 years ago
ec2000
model RM18F6WS Gibson small frezer bottom right side, ok once again not
cooling, i felt compresser its running very hot so i unpluged refrigerator
see if comes back on after cooling down
libertyappl
#8 Posted : 16 years ago
libertyappl
Remove the back panel in the freezer and check for ice there, if you have ice look for the defrost thermostat and test whith an ohm meter for continuity, if none the replace that part. Thaw completely with hair dryer which will get you by until you can get a partin and you will have to defrost it anyway.
Nat
ec2000
#9 Posted : 16 years ago
ec2000
thanks Nat, it came on again after being unpluged over nite ill try your
suggestion later today and let you know results Earl
ec2000
#10 Posted : 16 years ago
ec2000
ok Nat, the refridgerator quit coolinga again this afternoon,opening the
frezer door you can see the coils are frosted over,i removed 1 screw that
cover the fan however i also removed 2 more that looks like plastic cover
in back should pull off however it wont come off, im thinking the thermostat most likely would be there. now i havent give it the big pull
trying not to break that cover. so still trying to get deeper into back of
freezer Earl
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 6 months ago
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6 months ago
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6 months ago
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6 months ago
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6 months ago
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6 months ago
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6 months ago
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6 months ago
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 7 months ago
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 7 months ago
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 7 months ago
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 7 months ago
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 7 months ago
Refrigerator Ice (Refrigerator & Freezer Repair)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 8 months ago
2 Pages12>
