sounds like its running, but no cooling at all, any common things on this model ?
Touch your compressor to see if it's warm or if you hear a clikcing noise near the compressor. Nat
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
we unpluged it over nite now works,by doing that did we free up a relay or a error in a chip allowing it to work again. watching it closely see if happens again.
If it does that again repost with as much details as possible along with your complete model number Nat
model RM18F6WS Gibson small frezer bottom right side, ok once again not cooling, i felt compresser its running very hot so i unpluged refrigerator see if comes back on after cooling down
Remove the back panel in the freezer and check for ice there, if you have ice look for the defrost thermostat and test whith an ohm meter for continuity, if none the replace that part. Thaw completely with hair dryer which will get you by until you can get a partin and you will have to defrost it anyway. Nat
thanks Nat, it came on again after being unpluged over nite ill try your suggestion later today and let you know results Earl
ok Nat, the refridgerator quit coolinga again this afternoon,opening the frezer door you can see the coils are frosted over,i removed 1 screw that cover the fan however i also removed 2 more that looks like plastic cover in back should pull off however it wont come off, im thinking the thermostat most likely would be there. now i havent give it the big pull trying not to break that cover. so still trying to get deeper into back of freezer Earl
