3 Pages123>
raylamm05
#1 Posted : Thursday, December 9, 2010 11:19:31 AM(UTC)
raylamm05
No weather or power problems. I can program the keypad. Key pad and timers do what there supposed to. The problem is nothing kicks on to cook the food. There is no loud noise when I hit the start button. the time counts down and beeps at the end, but nothing happens as far as cooking. there is an inital clicking sound immediately after I push the start button. The turn table does not turn either.
Thank you,
Ray
#2 Posted : Thursday, December 9, 2010 1:55:05 PM(UTC)
Ray,
Did the cooling fan and the inner light work?
Here are the breakdown diagrams and Replacement parts for General Electric JE2160BF03 Counter top microwave | AppliancePartsPros.com
raylamm05
#3 Posted : Friday, December 10, 2010 5:39:40 AM(UTC)
raylamm05
Neither worked.
Ray,
raylamm05
#4 Posted : Friday, December 10, 2010 2:09:46 PM(UTC)
raylamm05
Neither works.
Ray,
raylamm05
#5 Posted : Friday, December 10, 2010 2:10:52 PM(UTC)
raylamm05
Neither works
#6 Posted : Friday, December 10, 2010 2:55:24 PM(UTC)
You may want to start the troubleshooting from the secondary interlock switch (the upper door switch). The easiest way to access the door switches is to remove the microwave outer case.
- The OEM switch Part number: AP2024331
- The substitute switch Part number: AP3186054
raylamm05
#7 Posted : Friday, December 10, 2010 3:50:02 PM(UTC)
raylamm05
Are you suggesting that I should replace the secondary interlock switch because the information I have supplied says that switch is most likely the problem or is there a way I can test this switch?
Ray
raylamm05
#8 Posted : Friday, December 10, 2010 3:51:54 PM(UTC)
raylamm05
Are you suggesting I replace the secondary switch, because the information I supplied implies that switch is most likely the problem or should I test the switch? How?
Ray
#9 Posted : Friday, December 10, 2010 4:08:02 PM(UTC)
This is very common issue but if you have an ohmmeter it is definitely better to check it first.
raylamm05
#10 Posted : Saturday, December 11, 2010 12:02:44 PM(UTC)
raylamm05
When I removed the case from the microwave, I manually pushed the what I believed to be the interlock switch. It did spark. Should I test it with the meter while I push the switch? When I put the meter to the connectors on the switch, with wires still attached I get a reading of -170ohms.
Guest (10)
Ge Advantium:Convection Works, Microwave doesn't work (Microwave Repair)
by domsue 1/30/2014 10:30:17 AM(UTC)
BRAND NEW microwave doesn't work (Microwave Repair)
by disneydenise 4/12/2010 5:48:35 PM(UTC)
Frigidarire Microwave doesn't work (Microwave Repair)
by ridge 9/29/2009 6:25:06 AM(UTC)
light under microwave doesn't work (Microwave Repair)
by denden8148 4/20/2009 9:48:42 AM(UTC)
by Novice 12/7/2008 10:37:44 AM(UTC)
3 Pages123>
