12 Pages«<56789>»
#61 Posted : 15 years ago
You are welcome Dave. Thank you for sharing your repair with us.
Happy Holidays and good luck with your microwave.
brendl
#62 Posted : 15 years ago
brendl
Thanks to everyones help. I have Whirlpool Micro that the handle broke and was able to replace it today in about 10 minutes. :)
rakinard
#63 Posted : 15 years ago
rakinard
I have Kitchen Aid (KHMS155LSS3). I tried to pry off #2 plastic layer and it broke. So I said what the heck and continued on. It still didn't matter --- even after I got #2 out of the way, I didn't have access to the screws that hold in the handle.
So now I am out $40 for the replacement door handle (well I guess I can return that), but my microwave still has a broke handle and the inside is all tore up.
Any more videos or suggestions? Anyone got a working microwave they want to sell me before my wife comes home?
#64 Posted : 15 years ago
I believe you can use the instructions from the following Service manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KHMS155LSS3 Microwave Hood Combination | AppliancePartsPros.com
kewaskum
#65 Posted : 15 years ago
kewaskum
I ordered the new handle for my 6 year old KHMS155LSS-1 and then read here how hard it is to replace.
I chosed to leave the door on the hinges (Kitchenaide says remove the door) and worked the choke cover off with patience.
Rather than try to get the little tabs free with a screwdriver, I bought a piece of vent pipe and cut a 1 inch wide strip off of it. I then worked this strip under the tabs (starting from the top edge away from the hinges). I used a putty knife to help get the tabs free while pushing the strip under. It was a pain but was done in about 5 minutes. The entire stainless panel then rotated off once the top was free.
I exposed the screws w/o taking it all the way off and replaced the handle. The stainless panel snapped back on and the choke cover went back in OK though I had to really push it in or the latch would not register correctly (light stays on, oven wont run even when door is closed).
I would recommend the Kitchenaide design engineer be fired for creating such a shoddy handle and then making its replacement so difficult...
Hope someone finds this useful... :)
Kewaskum
Originally Posted by: JAMES MUNN Go to Quoted Post
to MarkJ
Installation: The instructions which come with the part say "simple installation". While this is far from accurate, if you show a little patience and care you can save $$ on installation charges. The door assembly parts are what I call a "press fit". If you carefully force the issue by gradually working a thin screwdriver along the edge of the assembly, you will be able to separate the inside of the door frame to expose where the handle is actually attached to the outside of the door. The exploded assembly drawing is accurate in terms of the components/pieces involved.
I would also caution you to take care with the position of the glass. Once you remove the rear frame section, the glass may fall out of position. The method they used to retain the glass was poor at best. Now that I am aware of this, I would know to watch out for this event! I avoided breaking glass, but the reverse could have easily happened.
The design engineer DID NOT have the average home do it yourselfer in mind on this handle. There are also a number of ways they could have constructed the handle to avoid this flaw.
Good luck!
drealeo
#66 Posted : 15 years ago
drealeo
I have read this thread on how to install the handle. I have unsuccessfully installed my handle, instead I have now cracked the inner frame as a result of trying to pull the frame off to get to the screws which of course do not exist on this model. :rolleyes:
Is there anyone out there that can advise on how to effectively install this handle for this specific model?? Any assistance would be greatly appreciated!
Many thanks!!!
#67 Posted : 15 years ago
Many thanks!!!
Very likely you have to remove the whole door from the microwave prior to take it apart. You can use the Service manual link from the previous page of this thread.
ashbyrules
#68 Posted : 14 years ago
ashbyrules
Maybe I am missing something but I went over the manual and my Microwave looks different then the images in the service manual. I have a Whirlpool GH4155XPS0. I took the grill off the top but there isn't a torex screw there for door removal. Am I missing something staring me in the face?
#69 Posted : 14 years ago
The upper door hinge and the screw are shown as #26 & #18 on the diagram.
ashbyrules
#70 Posted : 14 years ago
ashbyrules
So for mine I need to peel away the choke cover to access that screw it looks like. Fun times.
GE Profile #PVM917DFBB microwave handle removal (Microwave Repair)
by trifive 5 years ago
microwave handle repair (Microwave Repair)
by rthill01 12 years ago
Replacing microwave handle (Microwave Repair)
by gregx5 14 years ago
Microwave handle (Microwave Repair)
by mrorvis 14 years ago
Microwave handle repair (Microwave Repair)
by rburton61 14 years ago
microwave handle broke off (Microwave Repair)
by bigbro 15 years ago
Installing Microwave handle (Microwave Repair)
by Buckey1 16 years ago
by gdevas 16 years ago
Microwave Handle (Microwave Repair)
by tyohe@yoheconsulting.com 16 years ago
Kenmore microwave handle repair (Microwave Repair)
by ginasal 16 years ago
Broken off GE Microwave Handle pn #AP3187809 (Microwave Repair)
by mrbotto 16 years ago
Microwave Handle replacement (Microwave Repair)
by Yusuf 16 years ago
Install GE Microwave handle (Microwave Repair)
by icandoitmyself454 16 years ago
How to install new microwave handle (Microwave Repair)
by Chalcook 16 years ago
GE Microwave Handle Replacement (Microwave Repair)
by Graham Brown 16 years ago
12 Pages«<56789>»
