rlingrel
#1 Posted : Thursday, August 21, 2008 10:45:42 AM(UTC)
rlingrel
I have just replaced the motor on my amana dryer, after plugging it back in closing the door and starting the dryer it started working great, or so I thought, the drum still does not turn, OK streched belt no problem I will replace that, however after I closed the door it continued to hum and after I removed the door panel I noticed that the heating element was still glowing as if it were running, what is causing this issue??
libertyappl
#2 Posted : Thursday, August 21, 2008 11:36:27 AM(UTC)
libertyappl
Please double check your model number I can't get it to pull up
Nat
rlingrel
#3 Posted : Thursday, August 21, 2008 12:05:01 PM(UTC)
rlingrel
Sorry doing this from memory and transposed numbers ALE643RBW
libertyappl
#4 Posted : Thursday, August 21, 2008 12:10:53 PM(UTC)
libertyappl
On your belt make sure you have it "treaded" correctly really not likely to have stretched that much.
And by looking at your breakdown I'd have to say that something is crosswired for the element to stay on like you stated
Check your connections.
Nat
rlingrel
#5 Posted : Tuesday, September 2, 2008 9:35:50 AM(UTC)
rlingrel
Nat
Thanks Nat, I had just plugged in the connector from the old to the new, it has me baffled, is it possible that the motor that was sent is wired wrong? you would think that with a plug in connector it would be difficult to cross wire? thoughts?
libertyappl
#6 Posted : Tuesday, September 2, 2008 10:01:56 AM(UTC)
libertyappl
It's possible, although not likely, that the motor is wired wrong. Did you happen to unplug anything else. I haven't been able to locate a wiring diagram on line to see if i can hp trace the problem. If you look in your control panel your tech sheet is placed there. Look at the wiring on the sheet from the element and trace the wires, note the colors listed and trace them on the dryer with an ohm meter seems like one of your thermostats is not functioning to allow the heater to cool down.
Nat
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Elite Electric Dryer not working (Dryer Repair)
by Guest 7/24/2022 7:10:35 AM(UTC)
GE Dryer Not Working (Dryer Repair)
by DWMarsh 4/14/2020 2:43:03 PM(UTC)
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 4:43:32 PM(UTC)
by Cynthia Sosa 9/25/2015 7:00:01 AM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 3:16:19 AM(UTC)
by cubbiesbp 3/11/2015 1:02:55 PM(UTC)
dryer not working on timed cycle (Dryer Repair)
by kwikk4 2/23/2015 7:53:40 AM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 9:59:33 AM(UTC)
by Vitocar 6/17/2014 11:12:39 AM(UTC)
dryer not working (surprise!) (Dryer Repair)
by thebrokenwhirlpool 3/8/2014 11:26:54 AM(UTC)
Dryer not working right (Dryer Repair)
by Monsters 10/1/2013 6:59:17 PM(UTC)
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
Roper dryer not working in auto sense mode. (Dryer Repair)
by CWeasel 7/15/2012 10:03:37 AM(UTC)
by redrider65 2/20/2012 1:25:39 PM(UTC)
