3 Pages123>
daneyed
#1 Posted : Wednesday, August 20, 2008 7:00:47 PM(UTC)
daneyed
I have an Ultimate Care II dryer and no heat is coming out of it.
libertyappl
#2 Posted : Wednesday, August 20, 2008 7:06:31 PM(UTC)
libertyappl
post your model number please.
Nat
daneyed
#3 Posted : Thursday, August 21, 2008 7:18:26 AM(UTC)
daneyed
I do not see a model #.
libertyappl
#4 Posted : Thursday, August 21, 2008 7:57:32 AM(UTC)
libertyappl
Open your dryer door, there's a tag around the opening where your clothes go.
Nat
daneyed
#5 Posted : Thursday, August 21, 2008 9:58:18 AM(UTC)
daneyed
Model# LEQ9508PW1
libertyappl
#6 Posted : Thursday, August 21, 2008 10:05:22 AM(UTC)
libertyappl
Thanks,
For starters lets start with the basics, go to your breaker box and turn the dryer breaker off wait a few seconds then turn it back on. Try the dryer see if it heats. If not then we'll move on to the next step. Get your ohm meter.
Nat
daneyed
#7 Posted : Thursday, August 21, 2008 12:03:15 PM(UTC)
daneyed
Did not work. What's next?
libertyappl
#8 Posted : Thursday, August 21, 2008 12:12:02 PM(UTC)
libertyappl
do you have an ohm meter?
libertyappl
#9 Posted : Thursday, August 21, 2008 12:40:41 PM(UTC)
libertyappl
If you have an ohm meter.... remove the rear panel and look at where the wires make connections. Remove one set of connections at a time and test for continuity on each thermostat, if one has continuity then replace wires and move to the next. If all the thermostats have continuity then unplug the element and test it.
Post your results.
Nat
daneyed
#10 Posted : Thursday, August 21, 2008 2:15:43 PM(UTC)
daneyed
No ohm meter.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
Belarus Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
3 Pages123>
